Flarum installing for hestiacp
I noticed you replied here about flarum but I am having this issue
Access Denied
You do not have permission to view this page.
Please check your credentials and try again.
Error Code: 403
I feel like I followed the guide pretty well and I still get this issue even after chmod 777 755 trying tutorials but I always get this issue.
I’ve tried making a flarum folder inside of public html, directly installing it in public html, making everything chmod 777, what else can I do?
Why don’t use Flarum Quick Install provided by Hestia?
I’ve installed it 5 minutes ago and it installed without issues.
Note: Before installing Flarum, check whether you have enabled proc_open. Edit the php.ini for your PHP cli version and remove it from directive disable_functions
Example for PHP 8.2:
Edit file:
/etc/php/8.2/cli/php.ini
And remove proc_open from this list:
disable_functions = pcntl_alarm,pcntl_fork,pcntl_waitpid,pcntl_wait,pcntl_wifexited,pcntl_wifstopped,pcntl_wifsignaled,pcntl_wifcontinued,pcntl_wexitstatus,pcntl_wtermsig,pcntl_wstopsig,pcntl_signal,pcntl_signal_dispatch,pcntl_get_last_error,pcntl_strerror,pcntl_sigprocmask,pcntl_sigwaitinfo,pcntl_sigtimedwait,pcntl_exec,pcntl_getpriority,pcntl_setpriority,exec,system,passthru,shell_exec,proc_open,popen
Because I didn’t know hestia had a quick install app, I will be looking for it but I have failed so far, I’ll briefly look over the forums cause the panel didn’t help.
Looks like I need to install this. nvm.
Oops! Something went wrong during a cross-origin request. Please reload the page and try again.
I used the quick install and I received this error above.
So you installed Flarum using Quick Install and it finished ok but when you try to access to your domain you see the cross-origin error?
Do you try to access using http or https? Did you add a certificate to your domain?
In your Flarum’s config.php file, what is the value of directive 'url'?
I try logging in and it give that error
  'url' => 'http://example.com',
Edit config.php, replace http by https and try again:
'url' => 'https://example.com',
Thank you mate! can you delete the url please or rebrand so other people can use this forum post as help! :pray:
You are welcome :wink:
Done, I’ve replaced your actual domain by example.com
