Flask (Port 5000) - proxy template question(s)?
I want to test running a local flask server (on port 5000) - used for receiving webhooks.
So I added a new proxy template (e.g. /usr/local/hestia/data/templates/web/nginx/flask-port-5000.tpl) with the following content:
server {
        error_log   /var/log/%web_system%/domains/%domain%.error.log error;
                deny all;
                return 404;
        location / {
                proxy_pass http://%ip%:5000;
        location /error/ {
Edited the domain I want to use and set:
Web-Vorlage APACHE2 to default
Backend-Vorlage PHP-FPM to no-php
Proxy-Vorlage to flask-port-5000
The first tests looking good :+1:
So the next question would be how to use flask with the ssl support?
  • Which content the file flask-port-5000.stpl need to have?
Is this ok?
server {
        listen      %ip%:%proxy_ssl_port% ssl;
        ssl_stapling        on;
        ssl_stapling_verify on;
        # TLS 1.3 0-RTT anti-replay
                deny all;
                return 404;
        location / {
                proxy_pass https://%ip%:5000;
        location /error/ {
        proxy_hide_header Upgrade;
The last question would be flask specific - how I should change the flask app so flask uses the hestia ssl certificates? Is this possible?
