Hello, I have been trying to integrate FOSSBilling with HestiaCP
So far, I have been able to install FOSSBilling and have it running.
Now I want to connect to the different servers.
I can enable the API here: v-change-sys-api enable api
I can whitelist the FOSSBilling server here: v-add-sys-api-ip 55.xxx.xxx.xxx
I can generate an API key with this command: v-generate-api-key
But I can’t fill the form because i don’t understand what are the two api fields about and how to generate.
Besides, I have read about “billing” api permissions but I can’t find where…
Use v-add-access-key instead, this is the recommended way to generate api keys and the one that will give you the Access Key ID and the Secret Access Key ;).
Note: to view the current api “roles” use v-list-apis command. You can create your own api “role” here /usr/local/hestia/data/api/ and add the commands that could be used by the user using that api “role”.
Hi @eris ,
You are right it is the easiest and fastest way to integrate.
@jlguerrero ,
I also have a server running very well +6 months now with Foosbilling and the method I selected the option in Admin and it worked instantly like referenced.
Very important note: you must ensure that the user and group privileges are set as per the recommendations else it will become a nightmare to troubleshoot.
