Fossbilling / Nginx template in need
For the past couple of days I’ve been trying to get Fossbilling to work on my Ubuntu/HestiaCP box (Nginx only, no Apache).
I tried to create a template for Fossbilling based on default.tpl / default.stpl, and the Fossbilling documentation.
Despite all the attempts, I could not get the URL rewrite to work.
If anyone can share a working template for Fossbilling / Nginx it will be greatly appreciated. Thank you.
Here is my latest build for fossbilling.stpl
Summary
server {
listen %ip%:%web_ssl_port% ssl;
root %sdocroot%;
access_log /var/log/nginx/domains/%domain%.log combined;
access_log /var/log/nginx/domains/%domain%.bytes bytes;
error_log /var/log/nginx/domains/%domain%.error.log error;
ssl_stapling        on;
ssl_stapling_verify on;
# TLS 1.3 0-RTT anti-replay
try_files $uri $uri/ @rewrite;
sendfile off;
include /etc/nginx/mime.types;
# Block access to sensitive files and return 404 to make it indistinguishable from a missing file
location ~* .(ini|sh|inc|bak|twig|sql)$ {
	return 404;
# Block access to hidden files except .well-known
	return 404;
# Disable PHP execution in /uploads
location ~* /uploads/.*\.php$ {
	return 404;
# Deny access to /data
location ~* /data/ {
	return 404;
location @rewrite {
	rewrite ^/page/(.*)$ /index.php?_url=/custompages/$1;
	rewrite ^/(.*)$ /index.php?_url=/$1;
location / {
	location ~* ^.+\.(jpeg|jpg|png|webp|gif|bmp|ico|svg|css|js)$ {
		expires max;
	location ~ [^/]\.php(/|$) {
		fastcgi_split_path_info ^(.+\.php)(/.+)$;
		fastcgi_index index.php;
		fastcgi_param PATH_INFO       $fastcgi_path_info;
		fastcgi_intercept_errors on;
		fastcgi_pass %backend_lsnr%;
location /error/ {
location /vstats/ {
proxy_hide_header Upgrade;
and web-templates/templates/nginx/php-fpm/fossbilling.stpl at master · jaapmarcus/web-templates · GitHub
Thank you so much, it works perfectly!
:hugs:
