Good day to all,
I am a week old on using hestiaCP migrating from 2 years of VestaCP and everything was running great. Yesterday, I decided to move to a new cloud server. I installed a fresh copy of hestiaCP on ubuntu 20.04. However, initial installation failed, I run installtion bash for a second time and installation was successful. However, when I go to server settings, clamav-daemon is not running. I have rebooted server several times, start/restart clamav-deamon but no success. Any ideas what I should to fix this will be highly appreciated.
How many memory do you have available on the server?
@eris 16GB
I had the same problem. I fixed it by purging clamAV and reinstalling it:
sudo apt purge clamav clamav-daemon
and:
sudo apt install clamav clamav-daemon
then it worked for me. I could stop and start it from the control panel.
hope it works for you.
Hi, thank you for the feedback.
