Hello!
I can not access FTP after Hestia Control Panel update from v1.7.8 to v1.8.1 version. It displays the following error: Failed to retrieve directory listing.
Also, I got an email with such content:
The upgrade script has generated additional notifications, which must be heeded urgently:
Manual Action Required [IMPORTANT]
To enable the “Enhanced and Optimized TLS” feature, we must update the NGINX configuration file (/etc/nginx/nginx.conf).
But for unknown reason or you edited it, may not be fully apply all the changes in this upgrade.
Please follow the default configuration file to sync it:
/usr/local/hestia/install/deb/nginx/nginx.confBacked up configuration file:
/root/hst_backups/120720230633/conf/nginx/nginx.conf
Here is the log from FileZilla:
Status: Resolving address of MYWEBSITE.net Status: Connecting to SERVER_IP:21… Status: Connection established, waiting for welcome message… Response: 220 FTP Server ready. Command: AUTH TLS Response: 234 AUTH TLS successful Status: Initializing TLS… Status: TLS connection established. Command: USER user_ftp Response: 331 Password required for user_ftp Command: PASS **************** Response: 230 User user_ftp logged in Command: CLNT FileZilla Response: 200 OK Command: OPTS UTF8 ON Response: 200 UTF8 set to on Command: PBSZ 0 Response: 200 PBSZ 0 successful Command: PROT P Response: 200 Protection set to Private Status: Logged in Status: Retrieving directory listing… Command: PWD Response: 257 / is the current directory Command: TYPE I Response: 200 Type set to I Command: PASV Response: 227 Entering Passive Mode (91,107,215,72,152,47). Command: MLSD Error: Connection timed out after 20 seconds of inactivity Error: Failed to retrieve directory listing Status: Disconnected from server Status: Resolving address of MYWEBSITE.net Status: Connecting to SERVER_IP:21… Status: Connection established, waiting for welcome message… Response: 220 FTP Server ready. Command: AUTH TLS Response: 234 AUTH TLS successful Status: Initializing TLS… Status: TLS connection established. Command: USER user_ftp Response: 331 Password required for user_ftp Command: PASS **************** Response: 230 User user_ftp logged in Command: CLNT FileZilla Response: 200 OK Command: OPTS UTF8 ON Response: 200 UTF8 set to on Command: PBSZ 0 Response: 200 PBSZ 0 successful Command: PROT P Response: 200 Protection set to Private Status: Logged in Status: Retrieving directory listing… Command: PWD Response: 257 / is the current directory Command: TYPE I Response: 200 Type set to I Command: PASV Response: 227 Entering Passive Mode (91,107,215,72,147,245). Command: MLSD Error: Connection timed out after 20 seconds of inactivity Error: Failed to retrieve directory listing
I have disabled the HestiaCP automatic updates. Any ideas how to fix it? Thank you.
