I have tried all the solutions that you have posted on the forum. I am giving my dev the IP of my panel but the FTP account says “invalid username and password” everytime he tries to login. I also tried using Filezilla. Here I am getting the following message the whole time:
I hope someone is able to help me with this.
eris
July 27, 2023, 7:01pm
2
What OS and what user made do connect
user or user_xxx
My own OS is Windows 10 and the FTP account looks like this :
the OS of my VPS is UBUNTU if you asked about that
Firewall of what? and basically Im new to this so could tell me where to find the var/log/auth.log?
eris
July 27, 2023, 7:37pm
7
Firewall of your server or provider …
This is the hestia panel firewall settings if that’s what you mean.
eris
July 27, 2023, 8:06pm
9
Check your provider if they have a firewall…
Also check /var/log/auth.log and see for any failed login via ftp
where do I find the /var/log/auth.log? Can you tell me the steps that I need to take in the panel?
This is the provider. The firewall is deactivated.
I dont know how I am asking hestia relatd questions here? You asked me to check firewall I did.
eris
July 27, 2023, 8:47pm
14
We except some basic system knowledge from our users. This has nothing to do with Hestia but with basic debugging skill.
If you can’t run tail -f -s0.1 /var/log/auth.log via your terminal / ssh / vnc / what every you use. It is a skill level issue…
Should I post what I see after running the command here?
@litespeed hello there!
Are you using your CloudFlare DNS for domain of your website?
go File —> Site Manager —> General —> Encryption: Only use plain FTP
try this solution!
