Ftp connect not working after update
Hello everyone. Suddenly I am not able to connect to my server ftp anymore with filezilla or any other client. OS: Ubuntu 22.04.5 LTS
I am using free cloudflare plan, but I did not changed any settings. I think it am not able to connect after I did sudo apt upgrade like one week ago, but I am not sure about it, maybe it was like that even earlier.
User is connecting from ssh and also file manager from hestia works also…
ftp -p 127.0.0.1:
230 Login successful.
Remote system type is UNIX.
Using binary mode to transfer files.
cat /var/log/auth.log
Jan 23 23:21:05 sls7 sudo: pam_unix(sudo:session): session opened for user root(uid=0) by (uid=1001)
Jan 23 23:21:05 sls7 sudo: pam_unix(sudo:session): session closed for user root
Jan 23 23:21:06 sls7 sudo: pam_unix(sudo:session): session opened for user root(uid=0) by (uid=1001)
Jan 23 23:21:06 sls7 sudo: pam_unix(sudo:session): session closed for user root
Hi @dencha
I can connect to your FTP server so looks like you have blocked yourself.
Check if your current client IP has been banned:
v-list-firewall-ban
If you see your ip:
v-delete-firewall-ban HereYourIP FTP
Yeah… I see my IP and its said chain: “RECIDIVE”.
I try to remove it, it somehow not doing it. Also it says i`ve just got ban by time, while I am not able to connect for week or more. Why it could ban me again and again?
If you are on RECIDIVE chain then you must delete the ip from that chain:
v-delete-firewall-ban HereYourIP RECIDIVE
Check fail2ban logs to know why it is blocking you.
It worked for now. Thanks! I will try to inspect it… This is how i should check log? tail -f /var/log/auth.log ?
Use this:
 grep -F ' Ban HereYourIP' /var/log/fail2ban.log*
If you always connect from the same ip you can whitelist it so fail2ban won’t ban you.
echo -e '[DEFAULT]\nignoreip = HereYourIP' > /etc/fail2ban/jail.d/whitelist.local
systemctl restart fail2ban
If you have a dynamic IP you can create a DDNS record (there are a few free services out there) and update it every time the ip changes and use that DDNS in ignoreip directive instead of the IP.
