FTP user based system
I have som issues when i upload to a site
it starts fine but after a while it disconnects
the server is on the local network
@crazytoo sorry but still the same: Please share your logs and describe your problem with more details - ftp has a session timer. Or do you speak about the session drops after you upload files?
We’re here to help, but please also help us with providing enough informations :slight_smile:.
As additional information: Due to security, I would anyway suggest to use sftp instead of ftp(s).
it when i start uploading
after some time it drops the connection
As I wrote, it is impossible to help you without more informations. We can’t see your logs or do a analyze of your server from here. Please read again my post and consider to help us to help you :slight_smile:.
What is the size of the file you are attempting to transfer?
Which FTP client are you using to upload the file to the server?
As general note FTP should never be used today (this was true also more than a decade ago), clear-text auth and unencrypted file transfer are no joke.
So I also suggest to try switching to SFTP
the usage of ftp is only on the local network
winscp
i think about 20mb for the max size
Winscp is also a SFTP client, so you only need to change the port from 21 to 22
