Gateway Timeout
The gateway did not receive a timely response from the upstream server or application.
I’m having problems uploading database file 8MB
I’ve change max_allowed_packet in the panel, that’s not the problem.
I looked for $cfg['ExecTimeLimit'] in config.inc.php and could not find it to edit.
The only php.ini file I can find and edit is in /usr/local/hestia/php/lib and I changed max_execution_time & max_input_time and that did not work.
Is there another file anywhere I can edit?
It looks like you edit the wrong config file - if you want to upload it on a website, checkout /etc/php/. Also have a look in the web log files, this may give you more ifnormation than “only” the timeout.
I looked in log and the only warning I see is:
[Warning] Aborted connection 91 to db: ‘unconnected’ user: ‘pma’ host: ‘localhost’ (Got timeout reading communication packets)
I edited php.ini in /etc/php/7.3 and /etc/php/7.4 and that did not work.
Funny thing is when I refresh phpmyadmin it’s uploaded the whole database.
I’ll keep having a look and see if I can sort it.
Can you please share more informations about your system? OS, Version, Hestia Version, Installation String (full version (–apache yes/no, not -a yes).
Dedicated server
Debian 10.3 (x86_64)
Hestia v1.1.1
bash hst-install.sh --multiphp yes -c no -t no -r 8090 -e [email protected] -p mypass -s mydomain.com
I’m getting the same 504 gateway timeout in hestia 1.2.3 when I import databases in phpmyadmin 1MB or over?
I’ve tried increasing values in:
/etc/php/7.3/fpm/php.ini
max_execution_time
/etc/nginx/nginx.conf
fastcgi_connect_timeout
fastcgi_read_timeout
fastcgi_send_timeout
proxy_connect_timeout
proxy_read_timeout
proxy_send_timeout
/etc/mysql/my.cnf
wait_timeout
Any ideas on how to fix this?
Thanks, Liam
So I found out that the gateway timeout was actually coming from the apache timeout setting which is 30 seconds.
I increased this timeout setting in apache2.conf and was able to see the true sql error in phpmyadmin.
/etc/apache2/apache2.conf
eris
August 16, 2020, 9:43pm
8
For large sql files I would always suggest use CLI. Way more save and reliable…
Command line interface.
mysqldump -u username -p databasename < dataimport.sql
I had the same problem, but I could also solve it by changing the seconds in apache2
eris
February 9, 2022, 4:22pm
12
Please creata a new topic it doesn’t make sense to update an 6 months old topic…
