Gateway Timeout wordpress
Gateway Timeout
The gateway did not receive a timely response from the upstream server or application.
Wordpress
it`s just rises the load till gets stucked all the 8 procesor go to 100% load and wen i open the website page i get the message gataway timeout … I try few fix that i find in search but none work for me if i stop the php8.2-fpm that i use from panel the load go to normal 0…
Have you checked the related weblog? Maybe that specific wordpress instance got hacked, are there also other websites on that server? If yes, suspend that specific domain or user and see if it runs properly. If yes, proceed with maldet or similar tools to scan the files for any abnormal content.
No i only have 1 domain on that server, only wen i start php it`s starts the load, if i stop the php no problem
Well you need to find out what web requests are causing the PHP processes. Check the web log as Raphael suggested.
I started with scan first “496149 files scanned” will take some time
This are from error logs (i removed the full domain not to make ad)
[Sat Nov 23 14:40:03.680365 2024] [proxy_fcgi:error] [pid 222811:tid 222863] [client 112.86.225.232:0] AH01079: failed to make connection to backend: localhost
[Sat Nov 23 14:40:04.373074 2024] [proxy:error] [pid 222812:tid 222846] (2)No such file or directory: AH02454: FCGI: attempt to connect to Unix domain socket /run/php/php8.2-fpm-xx-android.com.sock (localhost:8000) failed
[Sat Nov 23 14:40:04.375073 2024] [proxy_fcgi:error] [pid 222812:tid 222846] [client 217.113.194.8:0] AH01079: failed to make connection to backend: localhost
[Sat Nov 23 14:40:05.548939 2024] [proxy:error] [pid 222812:tid 222852] (2)No such file or directory: AH02454: FCGI: attempt to connect to Unix domain socket /run/php/php8.2-fpm-xx-android.com.sock (localhost:8000) failed
[Sat Nov 23 14:40:05.549000 2024] [proxy_fcgi:error] [pid 222812:tid 222852] [client 116.179.32.96:0] AH01079: failed to make connection to backend: localhost
[Sat Nov 23 14:40:09.152702 2024] [proxy:error] [pid 222811:tid 222867] (2)No such file or directory: AH02454: FCGI: attempt to connect to Unix domain socket /run/php/php8.2-fpm-xx-android.com.sock (localhost:8000) failed
[Sat Nov 23 14:40:09.152753 2024] [proxy_fcgi:error] [pid 222811:tid 222867] [client 17.241.219.171:0] AH01079: failed to make connection to backend: localhost
[Sat Nov 23 14:40:14.433638 2024] [proxy:error] [pid 222811:tid 222842] (2)No such file or directory: AH02454: FCGI: attempt to connect to Unix domain socket /run/php/php8.2-fpm-xx-android.com.sock (localhost:8000) failed
[Sat Nov 23 14:40:14.433692 2024] [proxy_fcgi:error] [pid 222811:tid 222842] [client 217.113.194.6:0] AH01079: failed to make connection to backend: localhost
Check the web log, to see what requests are hitting the site. The issue is resource usage from PHP processes, so you need to see what’s causing that
The error log will show the symptoms (connection timeouts) but it won’t show you the cause (what’s visiting your site)
Here i think is the problem (error log)
Traffic log is ok, just checked last 1000 lines, normal traffic (i have a wordpress website sincer 2012)
i wait maldet to scan all the files 147890/496149 nothing till now
What about ‘ps axu’
To know what is running.
Or maybe ‘top’
Check the normal traffic from bots.
Maldet is no warranty of being clean.
Since it is. Wordpress install you may download and update everything.
Just clear all PHP files and reinstall from the source.
I will wait for maldet to finish and i will install all the vps and hcp from the ground
maldet(295315): {scan} 354316/496149 files scanned: 0 hits 0 cleaned
netstat and ps
netstat -pan
Active Internet connections (servers and established)
Proto Recv-Q Send-Q Local Address           Foreign Address         State       PID/Program name
tcp        0      0 127.0.0.1:9000          0.0.0.0:*               LISTEN      1930738/php-fpm: ma
tcp        0      0 213.136.xx.xx:8443      0.0.0.0:*               LISTEN      133164/apache2
tcp        0      0 0.0.0.0:587             0.0.0.0:*               LISTEN      1957/exim4
tcp        0      0 0.0.0.0:993             0.0.0.0:*               LISTEN      1672/dovecot
tcp        0      0 0.0.0.0:995             0.0.0.0:*               LISTEN      1672/dovecot
tcp        0      0 0.0.0.0:143             0.0.0.0:*               LISTEN      1672/dovecot
tcp        0      0 0.0.0.0:25              0.0.0.0:*               LISTEN      1957/exim4
tcp        0      0 0.0.0.0:21              0.0.0.0:*               LISTEN      567/vsftpd
tcp        0      0 0.0.0.0:22              0.0.0.0:*               LISTEN      16093/sshd: /usr/sb
tcp        0      0 0.0.0.0:110             0.0.0.0:*               LISTEN      1672/dovecot
tcp        0      0 0.0.0.0:465             0.0.0.0:*               LISTEN      1957/exim4
tcp        0      0 213.136.xx.xx:8080      0.0.0.0:*               LISTEN      133164/apache2
tcp        0      0 127.0.0.1:8081          0.0.0.0:*               LISTEN      133164/apache2
tcp        0      0 127.0.0.1:8084          0.0.0.0:*               LISTEN      132362/nginx: maste
tcp        0      0 127.0.0.53:53           0.0.0.0:*               LISTEN      545/systemd-resolve
tcp        0      0 127.0.0.1:953           0.0.0.0:*               LISTEN      12561/named
tcp        0      0 127.0.0.1:53            0.0.0.0:*               LISTEN      12561/named
tcp        0      0 0.0.0.0:5758            0.0.0.0:*               LISTEN      1845/nginx: master
tcp        0      0 213.136.xx.xx:53        0.0.0.0:*               LISTEN      12561/named
tcp        0      0 213.136.xx.xx:80        0.0.0.0:*               LISTEN      132362/nginx: maste
tcp        0      0 213.136.xx.xx:443       0.0.0.0:*               LISTEN      132362/nginx: maste
tcp        0      0 127.0.0.1:3306          0.0.0.0:*               LISTEN      54854/mariadbd
tcp       25      0 213.136.xx.xx:8443      213.136.xx.xx:42444     CLOSE_WAIT  1331475/apache2
tcp        0      0 213.136.xx.xx:22        84.xx.xx.xx:58175     ESTABLISHED 292951/sshd: root@p
tcp       25      0 213.136.xx.xx:8443      213.136.xx.xx:42520     CLOSE_WAIT  1331475/apache2
tcp       25      0 213.136.xx.xx:8443      213.136.xx.xx:42488     CLOSE_WAIT  1331474/apache2
tcp       25      0 213.136.xx.xx:8443      213.136.xx.xx:42502     CLOSE_WAIT  1331475/apache2
tcp       25      0 213.136.xx.xx:8443      213.136.xx.xx:42442     CLOSE_WAIT  1331474/apache2
tcp        0      0 213.136.xx.xx:443       47.128.49.132:36686     ESTABLISHED 1332069/nginx: work
tcp        0      0 213.136.xx.xx:42538     213.136.xx.xx:8443      ESTABLISHED 1332069/nginx: work
tcp       25      0 213.136.xx.xx:8443      213.136.xx.xx:42438     CLOSE_WAIT  1331474/apache2
tcp        0      0 213.136.xx.xx:443       57.141.0.28:55994       ESTABLISHED 1332069/nginx: work
tcp       25      0 213.136.xx.xx:8443      213.136.xx.xx:42464     CLOSE_WAIT  1331475/apache2
tcp        0      0 213.136.xx.xx:42526     213.136.xx.xx:8443      FIN_WAIT2   -
tcp       25      0 213.136.xx.xx:8443      213.136.xx.xx:42466     CLOSE_WAIT  1331475/apache2
tcp       25      0 213.136.xx.xx:8443      213.136.xx.xx:42472     CLOSE_WAIT  1331475/apache2
tcp       25      0 213.136.xx.xx:8443      213.136.xx.xx:42456     CLOSE_WAIT  1331474/apache2
tcp       25      0 213.136.xx.xx:8443      213.136.xx.xx:42506     CLOSE_WAIT  1331474/apache2
tcp       25      0 213.136.xx.xx:8443      213.136.xx.xx:42510     CLOSE_WAIT  1331475/apache2
tcp       25      0 213.136.xx.xx:8443      213.136.xx.xx:42534     CLOSE_WAIT  1331475/apache2
tcp       25      0 213.136.xx.xx:8443      213.136.xx.xx:42482     CLOSE_WAIT  1331474/apache2
tcp        0      0 213.136.xx.xx:8443      213.136.xx.xx:42512     ESTABLISHED 1331474/apache2
tcp       25      0 213.136.xx.xx:8443      213.136.xx.xx:42496     CLOSE_WAIT  1331474/apache2
tcp       25      0 213.136.xx.xx:8443      213.136.xx.xx:42460     CLOSE_WAIT  1331475/apache2
tcp        0   7136 213.136.xx.xx:22        84.xx.xx.xx:58335     ESTABLISHED 338646/sshd: root@p
tcp       25      0 213.136.xx.xx:8443      213.136.xx.xx:42494     CLOSE_WAIT  1331474/apache2
tcp        0      0 213.136.xx.xx:443       116.179.32.215:28959    ESTABLISHED 1332069/nginx: work
tcp       25      0 213.136.xx.xx:8443      213.136.xx.xx:42450     CLOSE_WAIT  1331475/apache2
tcp       25      0 213.136.xx.xx:8443      213.136.xx.xx:42498     CLOSE_WAIT  1331474/apache2
tcp       25      0 213.136.xx.xx:8443      213.136.xx.xx:42454     CLOSE_WAIT  1331474/apache2
tcp        0      0 213.136.xx.xx:42520     213.136.xx.xx:8443      FIN_WAIT2   -
tcp       25      0 213.136.xx.xx:8443      213.136.xx.xx:42486     CLOSE_WAIT  1331474/apache2
tcp        0      0 213.136.xx.xx:443       66.249.66.68:62586      ESTABLISHED 1332069/nginx: work
tcp        0      0 213.136.xx.xx:42512     213.136.xx.xx:8443      ESTABLISHED 1332069/nginx: work
tcp        0      0 213.136.xx.xx:42434     213.136.xx.xx:8443      ESTABLISHED 1332069/nginx: work
tcp        0      0 213.136.xx.xx:42530     213.136.xx.xx:8443      FIN_WAIT2   -
tcp       25      0 213.136.xx.xx:8443      213.136.xx.xx:42446     CLOSE_WAIT  1331474/apache2
tcp        0      0 213.136.xx.xx:8443      213.136.xx.xx:42528     ESTABLISHED 1331475/apache2
tcp       25      0 213.136.xx.xx:8443      213.136.xx.xx:42458     CLOSE_WAIT  1331475/apache2
tcp       25      0 213.136.xx.xx:8443      213.136.xx.xx:42526     CLOSE_WAIT  1331474/apache2
tcp       25      0 213.136.xx.xx:8443      213.136.xx.xx:42462     CLOSE_WAIT  1331475/apache2
tcp       25      0 213.136.xx.xx:8443      213.136.xx.xx:42500     CLOSE_WAIT  1943883/apache2
tcp        0      0 213.136.xx.xx:443       220.181.108.176:19291   ESTABLISHED 1332069/nginx: work
tcp        0      0 213.136.xx.xx:42532     213.136.xx.xx:8443      FIN_WAIT2   -
tcp       25      0 213.136.xx.xx:8443      213.136.xx.xx:42518     CLOSE_WAIT  1331474/apache2
tcp       25      0 213.136.xx.xx:8443      213.136.xx.xx:42468     CLOSE_WAIT  1331475/apache2
tcp        0      0 213.136.xx.xx:8443      213.136.xx.xx:42434     ESTABLISHED 1331475/apache2
tcp       25      0 213.136.xx.xx:8443      213.136.xx.xx:42484     CLOSE_WAIT  1331475/apache2
tcp       25      0 213.136.xx.xx:8443      213.136.xx.xx:42530     CLOSE_WAIT  1331474/apache2
tcp        0      0 213.136.xx.xx:8443      213.136.xx.xx:42538     ESTABLISHED 1331474/apache2
tcp       25      0 213.136.xx.xx:8443      213.136.xx.xx:42524     CLOSE_WAIT  1331474/apache2
tcp        0      0 213.136.xx.xx:42528     213.136.xx.xx:8443      ESTABLISHED 1332069/nginx: work
tcp       25      0 213.136.xx.xx:8443      213.136.xx.xx:42436     CLOSE_WAIT  1331475/apache2
tcp       25      0 213.136.xx.xx:8443      213.136.xx.xx:42470     CLOSE_WAIT  1331475/apache2
tcp       25      0 213.136.xx.xx:8443      213.136.xx.xx:42478     CLOSE_WAIT  1331474/apache2
tcp       25      0 213.136.xx.xx:8443      213.136.xx.xx:42452     CLOSE_WAIT  1331475/apache2
tcp        0      0 213.136.xx.xx:8443      213.136.xx.xx:42514     ESTABLISHED 1331474/apache2
tcp        0      0 213.136.xx.xx:42534     213.136.xx.xx:8443      FIN_WAIT2   -
tcp       25      0 213.136.xx.xx:8443      213.136.xx.xx:42522     CLOSE_WAIT  1331474/apache2
tcp       25      0 213.136.xx.xx:8443      213.136.xx.xx:42532     CLOSE_WAIT  1331474/apache2
tcp        0      0 213.136.xx.xx:42514     213.136.xx.xx:8443      ESTABLISHED 1332069/nginx: work
tcp6       0      0 ::1:953                 :::*                    LISTEN      12561/named
tcp6       0      0 :::993                  :::*                    LISTEN      1672/dovecot
tcp6       0      0 :::995                  :::*                    LISTEN      1672/dovecot
tcp6       0      0 :::143                  :::*                    LISTEN      1672/dovecot
tcp6       0      0 :::22                   :::*                    LISTEN      16093/sshd: /usr/sb
tcp6       0      0 :::110                  :::*                    LISTEN      1672/dovecot
tcp6       0      0 fe80::250:xxxx:xxxx::53 :::*                    LISTEN      12561/named
udp        0      0 127.0.0.1:55046         127.0.0.53:53           ESTABLISHED 1332081/nginx: work
udp        0      0 127.0.0.1:55891         127.0.0.53:53           ESTABLISHED 1332070/nginx: work
udp        0      0 127.0.0.1:57576         127.0.0.53:53           ESTABLISHED 1332069/nginx: work
udp        0      0 127.0.0.1:58227         127.0.0.53:53           ESTABLISHED 1332071/nginx: work
udp        0      0 127.0.0.1:45625         127.0.0.53:53           ESTABLISHED 1332075/nginx: work
udp        0      0 127.0.0.1:47590         127.0.0.53:53           ESTABLISHED 1332077/nginx: work
udp        0      0 213.136.xx.xx:53        0.0.0.0:*                           12561/named
udp        0      0 127.0.0.1:53            0.0.0.0:*                           12561/named
udp        0      0 127.0.0.53:53           0.0.0.0:*                           545/systemd-resolve
udp        0      0 127.0.0.1:53732         127.0.0.53:53           ESTABLISHED 1332068/nginx: work
udp6       0      0 fe80::250:xxxx:xxxx::53 :::*                                12561/named
raw6       0      0 :::58                   :::*                    7           536/systemd-network
Active UNIX domain sockets (servers and established)```
Proto RefCnt Flags       Type       State         I-Node   PID/Program name     Path
unix  2      [ ACC ]     STREAM     LISTENING     20094    1958/php-fpm: maste  /run/hestia-php.sock
unix  2      [ ]         DGRAM                    1043412  292954/systemd       /run/user/0/systemd/notify
unix  2      [ ACC ]     STREAM     LISTENING     1043415  292954/systemd       /run/user/0/systemd/private
unix  2      [ ACC ]     STREAM     LISTENING     1046217  292954/systemd       /run/user/0/gnupg/S.dirmngr
unix  2      [ ACC ]     STREAM     LISTENING     1046219  292954/systemd       /run/user/0/gnupg/S.gpg-agent.browser
unix  2      [ ACC ]     STREAM     LISTENING     1046221  292954/systemd       /run/user/0/gnupg/S.gpg-agent.extra
unix  2      [ ACC ]     STREAM     LISTENING     1046223  292954/systemd       /run/user/0/gnupg/S.gpg-agent.ssh
unix  2      [ ACC ]     STREAM     LISTENING     1046225  292954/systemd       /run/user/0/gnupg/S.gpg-agent
unix  2      [ ACC ]     STREAM     LISTENING     1046227  292954/systemd       /run/user/0/pk-debconf-socket
unix  2      [ ACC ]     STREAM     LISTENING     18552    1/init               /run/acpid.socket
unix  2      [ ACC ]     STREAM     LISTENING     18554    1/init               /run/dbus/system_bus_socket
unix  2      [ ACC ]     STREAM     LISTENING     18556    1/init               /run/uuidd/request
unix  3      [ ]         DGRAM      CONNECTED     19527    1/init               /run/systemd/notify
unix  2      [ ACC ]     STREAM     LISTENING     19530    1/init               /run/systemd/private
unix  2      [ ACC ]     STREAM     LISTENING     19532    1/init               /run/systemd/userdb/io.systemd.DynamicUser
unix  2      [ ACC ]     STREAM     LISTENING     19533    1/init               /run/systemd/io.system.ManagedOOM
unix  2      [ ]         DGRAM                    19543    1/init               /run/systemd/journal/syslog
unix  10     [ ]         DGRAM      CONNECTED     19550    1/init               /run/systemd/journal/dev-log
unix  9      [ ]         DGRAM      CONNECTED     19552    1/init               /run/systemd/journal/socket
unix  2      [ ACC ]     STREAM     LISTENING     19554    1/init               /run/systemd/journal/stdout
unix  2      [ ACC ]     SEQPACKET  LISTENING     19557    1/init               /run/udev/control
unix  2      [ ACC ]     STREAM     LISTENING     14931    501/irqbalance       /run/irqbalance/irqbalance501.sock
unix  2      [ ACC ]     STREAM     LISTENING     13947    289/systemd-journal  /run/systemd/journal/io.systemd.journal
unix  2      [ ]         DGRAM                    8847759  1957/exim4           @/var/spool/exim4/exim_daemon_notify
unix  2      [ ACC ]     STREAM     LISTENING     8844255  1672/dovecot         /run/dovecot/stats-reader
unix  2      [ ACC ]     STREAM     LISTENING     8844256  1672/dovecot         /run/dovecot/stats-writer
unix  2      [ ACC ]     STREAM     LISTENING     8844257  1672/dovecot         /run/dovecot/replicator
unix  2      [ ACC ]     STREAM     LISTENING     8844258  1672/dovecot         /run/dovecot/replication-notify
unix  2      [ ACC ]     STREAM     LISTENING     8844259  1672/dovecot         /run/dovecot/login/pop3
unix  2      [ ACC ]     STREAM     LISTENING     8844260  1672/dovecot         /run/dovecot/old-stats
unix  2      [ ACC ]     STREAM     LISTENING     8844261  1672/dovecot         /run/dovecot/log-errors
unix  2      [ ACC ]     STREAM     LISTENING     8844262  1672/dovecot         /run/dovecot/ipc
unix  2      [ ACC ]     STREAM     LISTENING     8844263  1672/dovecot         /run/dovecot/login/ipc-proxy
unix  2      [ ACC ]     STREAM     LISTENING     8844264  1672/dovecot         /run/dovecot/indexer-worker
unix  2      [ ACC ]     STREAM     LISTENING     8844265  1672/dovecot         /run/dovecot/indexer
unix  2      [ ACC ]     STREAM     LISTENING     8844266  1672/dovecot         /run/dovecot/login/imap
unix  2      [ ACC ]     STREAM     LISTENING     18640    545/systemd-resolve  /run/systemd/resolve/io.systemd.Resolve
unix  2      [ ACC ]     STREAM     LISTENING     8844267  1672/dovecot         /run/dovecot/imap-master
unix  2      [ ACC ]     STREAM     LISTENING     8844268  1672/dovecot         /run/dovecot/imap-urlauth-worker
unix  2      [ ACC ]     STREAM     LISTENING     8844269  1672/dovecot         /run/dovecot/token-login/imap-urlauth
unix  2      [ ACC ]     STREAM     LISTENING     8844270  1672/dovecot         /run/dovecot/imap-urlauth
unix  2      [ ACC ]     STREAM     LISTENING     8844271  1672/dovecot         /run/dovecot/imap-hibernate
unix  2      [ ACC ]     STREAM     LISTENING     8844272  1672/dovecot         /run/dovecot/doveadm-server
unix  2      [ ACC ]     STREAM     LISTENING     8844273  1672/dovecot         /run/dovecot/dns-client
unix  2      [ ACC ]     STREAM     LISTENING     8844274  1672/dovecot         /run/dovecot/login/dns-client
unix  2      [ ACC ]     STREAM     LISTENING     8844275  1672/dovecot         /run/dovecot/director-admin
unix  2      [ ACC ]     STREAM     LISTENING     8844276  1672/dovecot         /run/dovecot/director-userdb
unix  2      [ ACC ]     STREAM     LISTENING     8844277  1672/dovecot         /run/dovecot/dict
unix  2      [ ACC ]     STREAM     LISTENING     8844278  1672/dovecot         /run/dovecot/dict-async
unix  2      [ ACC ]     STREAM     LISTENING     8844279  1672/dovecot         /run/dovecot/config
unix  2      [ ACC ]     STREAM     LISTENING     8844280  1672/dovecot         /run/dovecot/login/login
unix  2      [ ACC ]     STREAM     LISTENING     8844281  1672/dovecot         /run/dovecot/token-login/tokenlogin
unix  2      [ ACC ]     STREAM     LISTENING     8844282  1672/dovecot         /run/dovecot/auth-login
unix  2      [ ACC ]     STREAM     LISTENING     8844283  1672/dovecot         /run/dovecot/auth-client
unix  2      [ ACC ]     STREAM     LISTENING     8844284  1672/dovecot         /run/dovecot/auth-userdb
unix  2      [ ACC ]     STREAM     LISTENING     8844285  1672/dovecot         /run/dovecot/auth-master
unix  2      [ ACC ]     STREAM     LISTENING     8844286  1672/dovecot         /run/dovecot/auth-worker
unix  2      [ ACC ]     STREAM     LISTENING     20762    549/python3          /var/run/fail2ban/fail2ban.sock
unix  2      [ ACC ]     STREAM     LISTENING     9751588  1930738/php-fpm: ma  /run/php/php8.2-fpm-xx-android.com.sock
unix  2      [ ACC ]     STREAM     LISTENING     9751590  1930738/php-fpm: ma  /run/php/php8.2-fpm-xx.net.sock
unix  2      [ ACC ]     STREAM     LISTENING     197519   54854/mariadbd       /run/mysqld/mysqld.sock
unix  2      [ ACC ]     STREAM     LISTENING     23734    1672/dovecot         /run/dovecot/anvil
unix  2      [ ACC ]     STREAM     LISTENING     23735    1672/dovecot         /run/dovecot/anvil-auth-penalty
unix  2      [ ACC ]     STREAM     LISTENING     23736    1672/dovecot         /run/dovecot/master
unix  3      [ ]         STREAM     CONNECTED     8847774  132362/nginx: maste
unix  3      [ ]         STREAM     CONNECTED     9756083  1331474/apache2
unix  3      [ ]         STREAM     CONNECTED     9752318  1934448/php-fpm: po  /run/php/php8.2-fpm-xx-android.com.sock
unix  3      [ ]         STREAM     CONNECTED     9779291  1331474/apache2
unix  3      [ ]         STREAM     CONNECTING    0        -                    /run/php/php8.2-fpm-xx-android.com.sock
unix  3      [ ]         STREAM     CONNECTED     20093    1958/php-fpm: maste
unix  3      [ ]         DGRAM      CONNECTED     21666    326/systemd-udevd
unix  3      [ ]         STREAM     CONNECTED     9771792  1331474/apache2
unix  3      [ ]         STREAM     CONNECTED     14939    490/@dbus-daemon     /run/dbus/system_bus_socket
unix  3      [ ]         STREAM     CONNECTED     52827    16093/sshd: /usr/sb
unix  3      [ ]         STREAM     CONNECTED     9776182  1331474/apache2
unix  3      [ ]         STREAM     CONNECTED     18315    545/systemd-resolve
unix  3      [ ]         STREAM     CONNECTED     8847779  132362/nginx: maste
unix  3      [ ]         STREAM     CONNECTED     8847772  132362/nginx: maste
unix  2      [ ]         DGRAM      CONNECTED     1043405  292954/systemd
unix  3      [ ]         STREAM     CONNECTED     14947    540/polkitd
unix  3      [ ]         STREAM     CONNECTED     121285   37290/packagekitd
unix  3      [ ]         STREAM     CONNECTED     21652    326/systemd-udevd
unix  3      [ ]         STREAM     CONNECTED     9751030  1331475/apache2
unix  3      [ ]         STREAM     CONNECTED     9779285  1331475/apache2
unix  2      [ ]         DGRAM      CONNECTED     15835    506/systemd-logind
unix  2      [ ]         STREAM     CONNECTED     1111533  338646/sshd: root@p
unix  3      [ ]         DGRAM      CONNECTED     18253    472/systemd-timesyn
unix  3      [ ]         STREAM     CONNECTED     9770997  1331475/apache2
unix  3      [ ]         STREAM     CONNECTED     9771385  1331474/apache2
unix  3      [ ]         STREAM     CONNECTED     9750457  1933711/php-fpm: po  /run/php/php8.2-fpm-xx-android.com.sock
unix  3      [ ]         STREAM     CONNECTED     1049854  1/init               /run/systemd/journal/stdout
unix  3      [ ]         STREAM     CONNECTED     15876    565/python3
unix  3      [ ]         DGRAM      CONNECTED     21850    536/systemd-network
unix  3      [ ]         STREAM     CONNECTED     9770919  1331474/apache2
unix  3      [ ]         DGRAM      CONNECTED     18252    472/systemd-timesyn
unix  3      [ ]         DGRAM      CONNECTED     18561    1/init
unix  3      [ ]         STREAM     CONNECTED     8847768  132362/nginx: maste
unix  2      [ ]         DGRAM      CONNECTED     1049831  292951/sshd: root@p
unix  3      [ ]         DGRAM      CONNECTED     1043413  292954/systemd
unix  3      [ ]         STREAM     CONNECTED     18637    545/systemd-resolve
unix  3      [ ]         STREAM     CONNECTED     21851    536/systemd-network
unix  3      [ ]         STREAM     CONNECTED     18398    565/python3
unix  3      [ ]         STREAM     CONNECTED     18325    549/python3
unix  3      [ ]         STREAM     CONNECTED     14129    506/systemd-logind
unix  3      [ ]         STREAM     CONNECTED     9755109  1331474/apache2
unix  2      [ ]         STREAM     CONNECTED     9752354  1934592/php-fpm: po
unix  3      [ ]         STREAM     CONNECTED     119656   490/@dbus-daemon     /run/dbus/system_bus_socket
unix  2      [ ]         DGRAM      CONNECTED     1113707  338646/sshd: root@p
unix  3      [ ]         STREAM     CONNECTED     8845943  132362/nginx: maste
unix  3      [ ]         STREAM     CONNECTED     8847775  132362/nginx: maste
unix  3      [ ]         STREAM     CONNECTED     21904    502/python3
unix  3      [ ]         STREAM     CONNECTED     9765672  1331475/apache2
unix  3      [ ]         STREAM     CONNECTED     23691    1672/dovecot
unix  3      [ ]         STREAM     CONNECTED     18299    490/@dbus-daemon
unix  3      [ ]         STREAM     CONNECTED     9756044  1331475/apache2
unix  3      [ ]         STREAM     CONNECTED     8847778  132362/nginx: maste
unix  3      [ ]         STREAM     CONNECTED     9751465  1331474/apache2
unix  3      [ ]         STREAM     CONNECTED     9751585  1930738/php-fpm: ma
unix  3      [ ]         STREAM     CONNECTED     22176    1672/dovecot
unix  3      [ ]         STREAM     CONNECTED     19756    502/python3
unix  3      [ ]         STREAM     CONNECTED     18573    1/init               /run/systemd/journal/stdout
unix  2      [ ]         STREAM     CONNECTED     9750458  1933711/php-fpm: po
unix  3      [ ]         STREAM     CONNECTED     19014    1845/nginx: master
unix  3      [ ]         DGRAM      CONNECTED     21847    536/systemd-network
unix  3      [ ]         DGRAM      CONNECTED     1043414  292954/systemd
unix  2      [ ]         DGRAM      CONNECTED     1043393  292955/(sd-pam)
unix  3      [ ]         STREAM     CONNECTED     21875    1/init               /run/systemd/journal/stdout
unix  3      [ ]         STREAM     CONNECTED     18232    472/systemd-timesyn
unix  2      [ ]         DGRAM      CONNECTED     117540   37290/packagekitd
unix  3      [ ]         STREAM     CONNECTED     9771949  1331474/apache2
unix  3      [ ]         STREAM     CONNECTED     9771028  1331474/apache2
unix  3      [ ]         STREAM     CONNECTED     9756818  1933791/php-fpm: po  /run/php/php8.2-fpm-xx-android.com.sock
unix  3      [ ]         STREAM     CONNECTED     9756078  1331475/apache2
unix  3      [ ]         STREAM     CONNECTED     18301    490/@dbus-daemon     /run/dbus/system_bus_socket
unix  3      [ ]         STREAM     CONNECTED     9765641  1331474/apache2
unix  3      [ ]         STREAM     CONNECTED     1043417  292954/systemd
unix  3      [ ]         STREAM     CONNECTED     8847769  132362/nginx: maste
unix  3      [ ]         DGRAM      CONNECTED     21665    326/systemd-udevd
unix  3      [ ]         STREAM     CONNECTED     9770896  1331475/apache2
unix  3      [ ]         STREAM     CONNECTED     9761435  1331475/apache2
unix  2      [ ]         STREAM     CONNECTED     9756819  1933791/php-fpm: po
unix  3      [ ]         STREAM     CONNECTED     21752    488/accounts-daemon
unix  3      [ ]         STREAM     CONNECTED     1044414  490/@dbus-daemon     /run/dbus/system_bus_socket
unix  3      [ ]         STREAM     CONNECTED     8847771  132362/nginx: maste
unix  2      [ ]         DGRAM      CONNECTED     18631    545/systemd-resolve
unix  3      [ ]         STREAM     CONNECTED     18302    490/@dbus-daemon     /run/dbus/system_bus_socket
unix  3      [ ]         STREAM     CONNECTED     9752353  1934592/php-fpm: po  /run/php/php8.2-fpm-xx-android.com.sock
unix  3      [ ]         STREAM     CONNECTED     8845940  132362/nginx: maste
unix  3      [ ]         STREAM     CONNECTED     21827    536/systemd-network
unix  3      [ ]         DGRAM      CONNECTED     18560    1/init
unix  3      [ ]         STREAM     CONNECTED     9768792  1331475/apache2
unix  3      [ ]         STREAM     CONNECTED     9758898  1331475/apache2
unix  3      [ ]         STREAM     CONNECTED     14932    1/init               /run/systemd/journal/stdout
unix  2      [ ]         DGRAM      CONNECTED     14126    489/cron
unix  3      [ ]         STREAM     CONNECTED     18399    565/python3
unix  2      [ ]         DGRAM      CONNECTED     18298    490/@dbus-daemon
unix  3      [ ]         STREAM     CONNECTED     8847776  132362/nginx: maste
unix  3      [ ]         STREAM     CONNECTED     9773621  1331474/apache2
unix  3      [ ]         STREAM     CONNECTED     9755325  1331474/apache2
unix  3      [ ]         STREAM     CONNECTED     14969    490/@dbus-daemon     /run/dbus/system_bus_socket
unix  3      [ ]         STREAM     CONNECTED     19731    490/@dbus-daemon     /run/dbus/system_bus_socket
unix  2      [ ]         DGRAM      CONNECTED     21841    536/systemd-network
unix  3      [ ]         STREAM     CONNECTED     9776140  1331474/apache2
unix  3      [ ]         STREAM     CONNECTED     19013    1845/nginx: master
unix  3      [ ]         STREAM     CONNECTED     8847777  132362/nginx: maste
unix  3      [ ]         STREAM     CONNECTED     18701    565/python3
unix  3      [ ]         STREAM     CONNECTED     9751570  1930738/php-fpm: ma
unix  2      [ ]         STREAM     CONNECTED     1049817  292951/sshd: root@p
unix  3      [ ]         DGRAM      CONNECTED     19528    1/init
unix  3      [ ]         STREAM     CONNECTED     18564    490/@dbus-daemon
unix  3      [ ]         STREAM     CONNECTED     14946    490/@dbus-daemon     /run/dbus/system_bus_socket
unix  3      [ ]         STREAM     CONNECTED     18304    1/init               /run/systemd/journal/stdout
unix  2      [ ]         STREAM     CONNECTED     9753623  1931820/php-fpm: po
unix  3      [ ]         DGRAM      CONNECTED     18254    472/systemd-timesyn
unix  2      [ ]         STREAM     CONNECTED     9755328  1934190/php-fpm: po
unix  3      [ ]         STREAM     CONNECTED     9771360  1331474/apache2
unix  3      [ ]         STREAM     CONNECTED     8845942  132362/nginx: maste
unix  3      [ ]         STREAM     CONNECTED     8847782  132362/nginx: maste
unix  3      [ ]         STREAM     CONNECTED     8847773  132362/nginx: maste
unix  2      [ ]         STREAM     CONNECTED     9752319  1934448/php-fpm: po
unix  3      [ ]         STREAM     CONNECTED     15846    506/systemd-logind
unix  3      [ ]         STREAM     CONNECTED     15726    1/init               /run/systemd/journal/stdout
unix  3      [ ]         STREAM     CONNECTED     18643    1/init               /run/systemd/journal/stdout
unix  2      [ ]         DGRAM      CONNECTED     18247    472/systemd-timesyn
unix  3      [ ]         STREAM     CONNECTED     9772669  1331475/apache2
unix  3      [ ]         STREAM     CONNECTED     19757    1/init               /run/systemd/journal/stdout
unix  3      [ ]         STREAM     CONNECTED     1043381  292954/systemd
unix  3      [ ]         STREAM     CONNECTED     50925    1/init               /run/systemd/journal/stdout
unix  2      [ ]         DGRAM      CONNECTED     48279    12561/named
unix  3      [ ]         STREAM     CONNECTED     9754057  1933160/php-fpm: po  /run/php/php8.2-fpm-xx-android.com.sock
unix  3      [ ]         STREAM     CONNECTED     8847781  132362/nginx: maste
unix  3      [ ]         STREAM     CONNECTED     14124    1/init               /run/systemd/journal/stdout
unix  3      [ ]         STREAM     CONNECTED     9760114  1331475/apache2
unix  3      [ ]         STREAM     CONNECTED     20651    502/python3
unix  3      [ ]         STREAM     CONNECTED     9760341  1331475/apache2
unix  3      [ ]         STREAM     CONNECTED     9760140  1331475/apache2
unix  2      [ ]         DGRAM      CONNECTED     13949    289/systemd-journal
unix  3      [ ]         STREAM     CONNECTED     19698    489/cron
unix  3      [ ]         STREAM     CONNECTED     8847770  132362/nginx: maste
unix  3      [ ]         DGRAM      CONNECTED     21849    536/systemd-network
unix  3      [ ]         STREAM     CONNECTED     14160    1/init               /run/systemd/journal/stdout
unix  2      [ ]         STREAM     CONNECTED     9751411  1933311/php-fpm: po
unix  3      [ ]         STREAM     CONNECTED     9750638  1/init               /run/systemd/journal/stdout
unix  2      [ ]         STREAM     CONNECTED     9754058  1933160/php-fpm: po
unix  2      [ ]         DGRAM      CONNECTED     19607    1/init
unix  2      [ ]         DGRAM      CONNECTED     21661    326/systemd-udevd
unix  3      [ ]         STREAM     CONNECTED     9779345  1331474/apache2
unix  3      [ ]         STREAM     CONNECTED     9759924  1331475/apache2
unix  3      [ ]         STREAM     CONNECTED     9751410  1933311/php-fpm: po  /run/php/php8.2-fpm-xx-android.com.sock
unix  3      [ ]         STREAM     CONNECTED     123158   1/init               /run/systemd/journal/stdout
unix  2      [ ]         DGRAM      CONNECTED     14935    503/rsyslogd
unix  3      [ ]         STREAM     CONNECTED     9767698  1943883/apache2
unix  3      [ ]         STREAM     CONNECTED     9756128  1331474/apache2
unix  3      [ ]         STREAM     CONNECTED     9753622  1931820/php-fpm: po  /run/php/php8.2-fpm-xx-android.com.sock
unix  3      [ ]         STREAM     CONNECTED     15732    1/init
unix  3      [ ]         STREAM     CONNECTED     117537   37290/packagekitd
unix  3      [ ]         STREAM     CONNECTED     18285    1/init               /run/systemd/journal/stdout
unix  3      [ ]         STREAM     CONNECTED     20092    1958/php-fpm: maste
unix  3      [ ]         DGRAM      CONNECTED     21848    536/systemd-network
unix  3      [ ]         STREAM     CONNECTED     9756816  1331475/apache2
unix  3      [ ]         STREAM     CONNECTED     9771464  1331474/apache2
unix  3      [ ]         STREAM     CONNECTED     9771202  1331474/apache2
unix  3      [ ]         STREAM     CONNECTED     18300    490/@dbus-daemon
unix  3      [ ]         STREAM     CONNECTED     9755567  1331475/apache2
unix  3      [ ]         STREAM     CONNECTED     15866    490/@dbus-daemon     /run/dbus/system_bus_socket
unix  3      [ ]         STREAM     CONNECTED     14125    1/init               /run/systemd/journal/stdout
unix  3      [ ]         STREAM     CONNECTED     21736    1/init               /run/systemd/journal/stdout
unix  3      [ ]         STREAM     CONNECTED     24592    1/init               /run/systemd/journal/stdout
unix  3      [ ]         STREAM     CONNECTED     14162    567/vsftpd
unix  3      [ ]         STREAM     CONNECTED     9751586  1930738/php-fpm: ma
unix  3      [ ]         STREAM     CONNECTED     9771745  1331474/apache2
unix  3      [ ]         STREAM     CONNECTED     9762987  1331475/apache2
unix  3      [ ]         STREAM     CONNECTED     14925    501/irqbalance
unix  3      [ ]         DGRAM      CONNECTED     18251    472/systemd-timesyn
unix  3      [ ]         STREAM     CONNECTED     9770902  1331474/apache2
unix  3      [ ]         STREAM     CONNECTED     9755327  1934190/php-fpm: po  /run/php/php8.2-fpm-xx-android.com.sock
unix  3      [ ]         STREAM     CONNECTED     9751387  1331475/apache2
unix  3      [ ]         STREAM     CONNECTED     15025    490/@dbus-daemon     /run/dbus/system_bus_socket
unix  3      [ ]         STREAM     CONNECTED     8845941  132362/nginx: maste
unix  3      [ ]         STREAM     CONNECTED     21905    502/python3
unix  3      [ ]         DGRAM      CONNECTED     19529    1/init
unix  3      [ ]         STREAM     CONNECTED     23690    1672/dovecot
unix  3      [ ]         STREAM     CONNECTED     18272    472/systemd-timesyn
unix  3      [ ]         STREAM     CONNECTED     9767018  1331474/apache2
unix  3      [ ]         STREAM     CONNECTED     13992    1/init               /run/systemd/journal/stdout
PS
root@vmi2064664:/home/cexxec/web/free-apps-android.com/logs# ps aux
USER         PID %CPU %MEM    VSZ   RSS TTY      STAT START   TIME COMMAND
root           1  0.0  0.0 167152 12656 ?        Ss   Nov22   2:47 /sbin/init
root           2  0.0  0.0      0     0 ?        S    Nov22   0:00 [kthreadd]
root           3  0.0  0.0      0     0 ?        I<   Nov22   0:00 [rcu_gp]
root           4  0.0  0.0      0     0 ?        I<   Nov22   0:00 [rcu_par_gp]
root           6  0.0  0.0      0     0 ?        I<   Nov22   0:00 [kworker/0:0H-events_highpri]
root           9  0.0  0.0      0     0 ?        I<   Nov22   0:00 [mm_percpu_wq]
root          10  0.0  0.0      0     0 ?        S    Nov22   0:00 [rcu_tasks_rude_]
root          11  0.0  0.0      0     0 ?        S    Nov22   0:00 [rcu_tasks_trace]
root          12  0.0  0.0      0     0 ?        S    Nov22   0:13 [ksoftirqd/0]
root          13  0.5  0.0      0     0 ?        I    Nov22  22:42 [rcu_sched]
root          14  0.0  0.0      0     0 ?        S    Nov22   0:02 [migration/0]
root          15  0.0  0.0      0     0 ?        S    Nov22   0:00 [idle_inject/0]
root          16  0.0  0.0      0     0 ?        S    Nov22   0:00 [cpuhp/0]
root          17  0.0  0.0      0     0 ?        S    Nov22   0:00 [cpuhp/1]
root          18  0.0  0.0      0     0 ?        S    Nov22   0:00 [idle_inject/1]
root          19  0.0  0.0      0     0 ?        S    Nov22   0:02 [migration/1]
root          20  0.0  0.0      0     0 ?        S    Nov22   0:14 [ksoftirqd/1]
root          22  0.0  0.0      0     0 ?        I<   Nov22   0:00 [kworker/1:0H-events_highpri]
root          23  0.0  0.0      0     0 ?        S    Nov22   0:00 [cpuhp/2]
root          24  0.0  0.0      0     0 ?        S    Nov22   0:00 [idle_inject/2]
root          25  0.0  0.0      0     0 ?        S    Nov22   0:02 [migration/2]
root          26  0.0  0.0      0     0 ?        S    Nov22   0:16 [ksoftirqd/2]
root          28  0.0  0.0      0     0 ?        I<   Nov22   0:00 [kworker/2:0H-events_highpri]
root          29  0.0  0.0      0     0 ?        S    Nov22   0:00 [cpuhp/3]
root          30  0.0  0.0      0     0 ?        S    Nov22   0:00 [idle_inject/3]
root          31  0.0  0.0      0     0 ?        S    Nov22   0:02 [migration/3]
root          32  0.0  0.0      0     0 ?        S    Nov22   0:15 [ksoftirqd/3]
root          34  0.0  0.0      0     0 ?        I<   Nov22   0:00 [kworker/3:0H-events_highpri]
root          35  0.0  0.0      0     0 ?        S    Nov22   0:00 [cpuhp/4]
root          36  0.0  0.0      0     0 ?        S    Nov22   0:00 [idle_inject/4]
root          37  0.0  0.0      0     0 ?        S    Nov22   0:02 [migration/4]
root          38  0.0  0.0      0     0 ?        S    Nov22   0:17 [ksoftirqd/4]
root          40  0.0  0.0      0     0 ?        I<   Nov22   0:00 [kworker/4:0H-events_highpri]
root          41  0.0  0.0      0     0 ?        S    Nov22   0:00 [cpuhp/5]
root          42  0.0  0.0      0     0 ?        S    Nov22   0:00 [idle_inject/5]
root          43  0.0  0.0      0     0 ?        S    Nov22   0:02 [migration/5]
root          44  0.0  0.0      0     0 ?        S    Nov22   0:15 [ksoftirqd/5]
root          46  0.0  0.0      0     0 ?        I<   Nov22   0:00 [kworker/5:0H-events_highpri]
root          47  0.0  0.0      0     0 ?        S    Nov22   0:00 [cpuhp/6]
root          48  0.0  0.0      0     0 ?        S    Nov22   0:00 [idle_inject/6]
root          49  0.0  0.0      0     0 ?        S    Nov22   0:02 [migration/6]
root          50  0.0  0.0      0     0 ?        S    Nov22   0:12 [ksoftirqd/6]
root          52  0.0  0.0      0     0 ?        I<   Nov22   0:00 [kworker/6:0H-events_highpri]
root          53  0.0  0.0      0     0 ?        S    Nov22   0:00 [cpuhp/7]
root          54  0.0  0.0      0     0 ?        S    Nov22   0:00 [idle_inject/7]
root          55  0.0  0.0      0     0 ?        S    Nov22   0:02 [migration/7]
root          56  0.0  0.0      0     0 ?        S    Nov22   0:12 [ksoftirqd/7]
root          58  0.0  0.0      0     0 ?        I<   Nov22   0:00 [kworker/7:0H-kblockd]
root          59  0.0  0.0      0     0 ?        S    Nov22   0:00 [kdevtmpfs]
root          60  0.0  0.0      0     0 ?        I<   Nov22   0:00 [netns]
root          61  0.0  0.0      0     0 ?        I<   Nov22   0:00 [inet_frag_wq]
root          62  0.0  0.0      0     0 ?        S    Nov22   0:00 [kauditd]
root          63  0.0  0.0      0     0 ?        S    Nov22   0:00 [khungtaskd]
root          64  0.0  0.0      0     0 ?        S    Nov22   0:00 [oom_reaper]
root          65  0.0  0.0      0     0 ?        I<   Nov22   0:00 [writeback]
root          66  0.0  0.0      0     0 ?        S    Nov22   0:39 [kcompactd0]
root          67  0.0  0.0      0     0 ?        SN   Nov22   0:00 [ksmd]
root          68  0.0  0.0      0     0 ?        SN   Nov22   0:19 [khugepaged]
root         115  0.0  0.0      0     0 ?        I<   Nov22   0:00 [kintegrityd]
root         116  0.0  0.0      0     0 ?        I<   Nov22   0:00 [kblockd]
root         117  0.0  0.0      0     0 ?        I<   Nov22   0:00 [blkcg_punt_bio]
root         118  0.0  0.0      0     0 ?        I<   Nov22   0:00 [tpm_dev_wq]
root         119  0.0  0.0      0     0 ?        I<   Nov22   0:00 [ata_sff]
root         120  0.0  0.0      0     0 ?        I<   Nov22   0:00 [md]
root         121  0.0  0.0      0     0 ?        I<   Nov22   0:00 [edac-poller]
root         122  0.0  0.0      0     0 ?        I<   Nov22   0:00 [devfreq_wq]
root         123  0.0  0.0      0     0 ?        S    Nov22   0:00 [watchdogd]
root         125  0.0  0.0      0     0 ?        I<   Nov22   0:00 [kworker/0:1H-kblockd]
root         127  0.0  0.0      0     0 ?        S    Nov22   0:51 [kswapd0]
root         128  0.0  0.0      0     0 ?        S    Nov22   0:00 [ecryptfs-kthrea]
root         131  0.0  0.0      0     0 ?        I<   Nov22   0:00 [kthrotld]
root         132  0.0  0.0      0     0 ?        I<   Nov22   0:00 [acpi_thermal_pm]
root         134  0.0  0.0      0     0 ?        S    Nov22   0:00 [scsi_eh_0]
root         135  0.0  0.0      0     0 ?        I<   Nov22   0:00 [scsi_tmf_0]
root         136  0.0  0.0      0     0 ?        S    Nov22   0:00 [scsi_eh_1]
root         137  0.0  0.0      0     0 ?        I<   Nov22   0:00 [scsi_tmf_1]
root         139  0.0  0.0      0     0 ?        I<   Nov22   0:00 [vfio-irqfd-clea]
root         140  0.0  0.0      0     0 ?        I<   Nov22   0:00 [mld]
root         141  0.0  0.0      0     0 ?        I<   Nov22   0:01 [kworker/3:1H-kblockd]
root         142  0.0  0.0      0     0 ?        I<   Nov22   0:00 [ipv6_addrconf]
root         156  0.0  0.0      0     0 ?        I<   Nov22   0:00 [kstrp]
root         161  0.0  0.0      0     0 ?        I<   Nov22   0:00 [zswap-shrink]
root         162  0.0  0.0      0     0 ?        I<   Nov22   0:00 [kworker/u17:0]
root         167  0.0  0.0      0     0 ?        I<   Nov22   0:00 [charger_manager]
root         189  0.0  0.0      0     0 ?        I<   Nov22   0:01 [kworker/1:1H-kblockd]
root         221  0.0  0.0      0     0 ?        S    Nov22   0:00 [scsi_eh_2]
root         223  0.0  0.0      0     0 ?        I<   Nov22   0:00 [scsi_tmf_2]
root         227  0.0  0.0      0     0 ?        I<   Nov22   0:02 [kworker/4:1H-kblockd]
root         228  0.0  0.0      0     0 ?        I<   Nov22   0:00 [kworker/2:1H-kblockd]
root         248  0.0  0.0      0     0 ?        I<   Nov22   0:01 [kworker/7:1H-kblockd]
root         250  0.0  0.0      0     0 ?        S    Nov22   0:29 [jbd2/sda3-8]
root         251  0.0  0.0      0     0 ?        I<   Nov22   0:00 [ext4-rsv-conver]
root         264  0.0  0.0      0     0 ?        I<   Nov22   0:01 [kworker/6:1H-kblockd]
root         283  0.0  0.0      0     0 ?        I<   Nov22   0:02 [kworker/5:1H-kblockd]
root         289  0.0  0.1  76764 37312 ?        S<s  Nov22   1:08 /lib/systemd/systemd-journald
root         326  0.0  0.0  11524  5872 ?        Ss   Nov22   0:01 /lib/systemd/systemd-udevd
root         360  0.0  0.0      0     0 ?        I<   Nov22   0:00 [cryptd]
root         403  0.0  0.0      0     0 ?        S    Nov22   0:00 [jbd2/sda2-8]
root         404  0.0  0.0      0     0 ?        I<   Nov22   0:00 [ext4-rsv-conver]
systemd+     472  0.0  0.0  89388  6316 ?        Ssl  Nov22   0:02 /lib/systemd/systemd-timesyncd
root         488  0.0  0.0 239940  7536 ?        Ssl  Nov22   0:27 /usr/libexec/accounts-daemon
root         489  0.0  0.0   9520  2860 ?        Ss   Nov22   0:07 /usr/sbin/cron -f -P
message+     490  0.0  0.0   8688  4456 ?        Ss   Nov22   1:32 @dbus-daemon --system --address=systemd: --nofork --nopidfile --systemd-activation --syslog-only
root         501  0.0  0.0  82780  3764 ?        Ssl  Nov22   0:17 /usr/sbin/irqbalance --foreground
root         502  0.0  0.0  35496 18876 ?        Ss   Nov22   0:00 /usr/bin/python3 /usr/bin/networkd-dispatcher --run-startup-triggers
syslog       503  0.0  0.0 222408  5720 ?        Ssl  Nov22   0:33 /usr/sbin/rsyslogd -n -iNONE
root         506  0.0  0.0  15532  7500 ?        Ss   Nov22   0:47 /lib/systemd/systemd-logind
systemd+     536  0.0  0.0  16152  7952 ?        Ss   Nov22   0:01 /lib/systemd/systemd-networkd
root         540  0.0  0.0 234536  6556 ?        Ssl  Nov22   0:00 /usr/libexec/polkitd --no-debug
systemd+     545  0.0  0.0  25820 12772 ?        Ss   Nov22   0:16 /lib/systemd/systemd-resolved
root         549  0.5  0.1 1288744 26520 ?       Ssl  Nov22  24:53 /usr/bin/python3 /usr/bin/fail2ban-server -xf start
root         565  0.0  0.0 112520 21336 ?        Ssl  Nov22   0:00 /usr/bin/python3 /usr/share/unattended-upgrades/unattended-upgrade-shutdown --wait-for-signal
root         567  0.0  0.0  10868  5964 ?        Ss   Nov22   0:00 /usr/sbin/vsftpd /etc/vsftpd.conf
root         572  0.0  0.0   8776   928 tty1     Ss+  Nov22   0:00 /sbin/agetty -o -p -- \u --noclear tty1 linux
root        1672  0.0  0.0   8324  4564 ?        Ss   Nov22   0:02 /usr/sbin/dovecot -F
dovecot     1755  0.0  0.0   4664  1380 ?        S    Nov22   0:01 dovecot/anvil
root        1845  0.0  0.0  21224  1324 ?        Ss   Nov22   0:00 nginx: master process /usr/local/hestia/nginx/sbin/hestia-nginx
admin       1846  0.0  0.0  22500  7556 ?        S    Nov22   0:02 nginx: worker process
Debian-+    1957  0.0  0.1  52540 27028 ?        Ss   Nov22   0:13 /usr/sbin/exim4 -bd -q30m
root        1958  0.0  0.0  83888  7080 ?        Ss   Nov22   0:24 php-fpm: master process (/usr/local/hestia/php/etc/php-fpm.conf)
bind       12561  0.0  0.0 1605624 13628 ?       Ssl  Nov22   0:45 /usr/sbin/named -u bind
root       16093  0.0  0.0  15456  8232 ?        Ss   Nov22   0:13 sshd: /usr/sbin/sshd -D [listener] 0 of 10-100 startups
root       37290  0.0  0.0 298228 18756 ?        Ssl  Nov22   0:03 /usr/libexec/packagekitd
mysql      54854  0.1  2.3 2543724 578480 ?      Ssl  Nov22   7:53 /usr/sbin/mariadbd
root       54857  0.0  0.0      0     0 ?        S    Nov22   0:00 [psimon]
root      132362  0.0  0.0  55504  9720 ?        Ss   Nov23   0:00 nginx: master process /usr/sbin/nginx -c /etc/nginx/nginx.conf
root      133164  0.0  0.0  17828 12320 ?        Ss   Nov23   0:24 /usr/sbin/apache2 -k start
root      292951  0.0  0.0  17192 10824 ?        Ss   Nov23   1:44 sshd: root@pts/0
root      292954  0.0  0.0  16964  9288 ?        Ss   Nov23   0:00 /lib/systemd/systemd --user
root      292955  0.0  0.0 169148  3804 ?        S    Nov23   0:00 (sd-pam)
root      292981  0.0  0.0  11376  4752 pts/0    Ss   Nov23   0:00 -bash
root      295315 18.7  0.0  25836 19508 pts/0    S+   Nov23 526:21 bash /usr/local/sbin/maldet --scan-all /home
root      338646  0.0  0.0  17348 10588 ?        Ss   Nov23   0:00 sshd: root@pts/1
root      338833  0.0  0.0  11388  5560 pts/1    Ss   Nov23   0:00 -bash
root      571493  0.0  0.0      0     0 ?        I    01:17   0:07 [kworker/2:1-events]
root      698274  0.0  0.0      0     0 ?        I    02:24   0:05 [kworker/5:0-mm_percpu_wq]
root     1115824  0.0  0.0      0     0 ?        I    06:07   0:05 [kworker/1:1-mm_percpu_wq]
root     1115826  0.0  0.0      0     0 ?        I    06:07   0:04 [kworker/3:0-mm_percpu_wq]
www-data 1331460  0.0  0.0  17720  5972 ?        S    07:50   0:00 /usr/sbin/apache2 -k start
www-data 1331474  0.0  0.1 1951276 25452 ?       Sl   07:50   0:12 /usr/sbin/apache2 -k start
www-data 1331475  0.0  0.0 1950280 24568 ?       Sl   07:50   0:07 /usr/sbin/apache2 -k start
root     1331568  0.0  0.0   4804  2984 ?        S    07:50   0:00 dovecot/log
www-data 1332068  0.0  0.0  55816 10824 ?        S    07:50   0:00 nginx: worker process
www-data 1332069  0.2  0.0  55816 13208 ?        S    07:50   0:41 nginx: worker process
www-data 1332070  0.0  0.0  55816 11620 ?        S    07:50   0:00 nginx: worker process
www-data 1332071  0.0  0.0  55816 10760 ?        S    07:50   0:00 nginx: worker process
www-data 1332075  0.0  0.0  55816 10760 ?        S    07:50   0:00 nginx: worker process
www-data 1332077  0.0  0.0  55816 10760 ?        S    07:50   0:00 nginx: worker process
www-data 1332079  0.0  0.0  55816  6772 ?        S    07:50   0:00 nginx: worker process
www-data 1332081  0.0  0.0  55816 10824 ?        S    07:50   0:00 nginx: worker process
www-data 1332082  0.0  0.0  55816  6456 ?        S    07:50   0:00 nginx: cache manager process
root     1335585  0.0  0.0   6912  4804 ?        S    07:52   0:00 dovecot/config
dovecot  1335586  0.0  0.0   5760  3432 ?        S    07:52   0:00 dovecot/stats
root     1540134  0.0  0.0      0     0 ?        I    09:43   0:01 [kworker/6:0-mm_percpu_wq]
root     1664082  0.0  0.0      0     0 ?        I    10:51   0:01 [kworker/7:2-mm_percpu_wq]
root     1769443  0.0  0.0      0     0 ?        I    11:47   0:00 [kworker/4:1-events]
root     1771747  0.0  0.0      0     0 ?        I    11:48   0:01 [kworker/0:1-events]
root     1865752  0.0  0.0      0     0 ?        I    12:42   0:01 [kworker/u16:3-events_unbound]
root     1894573  0.0  0.0      0     0 ?        I    12:57   0:00 [kworker/6:2-events]
root     1914364  0.0  0.0      0     0 ?        I    13:08   0:00 [kworker/1:0]
root     1917248  0.0  0.0      0     0 ?        I    13:10   0:00 [kworker/3:2-events]
root     1922335  0.0  0.0      0     0 ?        I    13:12   0:00 [kworker/u16:1-events_unbound]
root     1925511  0.0  0.0      0     0 ?        I    13:14   0:00 [kworker/5:2-events]
root     1926981  0.0  0.0      0     0 ?        I    13:14   0:00 [kworker/2:0-events]
root     1926982  0.0  0.0      0     0 ?        I    13:14   0:00 [kworker/0:0-events]
root     1928302  0.0  0.0      0     0 ?        I    13:14   0:00 [kworker/u16:4-events_power_efficient]
root     1929094  0.0  0.0      0     0 ?        I    13:14   0:00 [kworker/7:1]
root     1929097  0.0  0.0      0     0 ?        I    13:14   0:00 [kworker/4:2-mm_percpu_wq]
root     1930738  0.0  0.1 305548 40936 ?        Ss   13:14   0:00 php-fpm: master process (/etc/php/8.2/fpm/php-fpm.conf)
cexxec   1931820 82.3  7.1 2012020 1765616 ?     R    13:15   7:58 php-fpm: pool xx-android.com
cexxec   1933160 86.8  7.2 2040704 1785148 ?     R    13:15   8:12 php-fpm: pool xx-android.com
cexxec   1933311 86.8  7.2 2042752 1787400 ?     R    13:15   8:08 php-fpm: pool xx-android.com
cexxec   1933711 86.2  6.9 1964928 1709660 ?     R    13:15   7:52 php-fpm: pool xx-android.com
cexxec   1933791 86.4  6.9 1962880 1708472 ?     R    13:15   7:51 php-fpm: pool xx-android.com
cexxec   1934190 86.1  6.6 1903488 1647772 ?     R    13:15   7:35 php-fpm: pool xx-android.com
cexxec   1934448 81.9  6.2 1801088 1545944 ?     R    13:16   7:04 php-fpm: pool xx-android.com
cexxec   1934592 86.4  6.4 1854336 1599080 ?     R    13:16   7:22 php-fpm: pool xx-android.com
www-data 1943883  0.0  0.0 1944136 10916 ?       Sl   13:21   0:00 /usr/sbin/apache2 -k start
root     1945838  0.0  0.0      0     0 ?        I    13:23   0:00 [kworker/2:2-events]
root     1947954  0.0  0.0  25836 17476 pts/0    S+   13:24   0:00 bash /usr/local/sbin/maldet --scan-all /home
root     1947955  0.0  0.0  25836 17440 pts/0    R+   13:24   0:00 bash /usr/local/sbin/maldet --scan-all /home
root     1947956  0.0  0.0  25836 17440 pts/0    R+   13:24   0:00 bash /usr/local/sbin/maldet --scan-all /home
root     1947957  0.0  0.0  12672  1540 pts/1    R+   13:24   0:00 ps aux
top - 22:05:16 up  9:39,  2 users,  load average: 8.47, 8.44, 8.34
Tasks: 186 total,   9 running, 177 sleeping,   0 stopped,   0 zombie
%Cpu(s): 24.5 us, 75.0 sy,  0.0 ni,  0.0 id,  0.0 wa,  0.0 hi,  0.5 si,  0.0 st
MiB Mem :  24028.4 total,  21731.1 free,   1976.3 used,    320.9 buff/cache
MiB Swap:      0.0 total,      0.0 free,      0.0 used.  21631.2 avail Mem
    PID USER      PR  NI    VIRT    RES    SHR S  %CPU  %MEM     TIME+ COMMAND
  98564 cezar     20   0  849920 208708  49496 R 100.0   0.8  62:08.36 php-fpm8.2
  98534 cezar     20   0  851968 210456  49496 R  99.7   0.9  63:26.05 php-fpm8.2
  98538 cezar     20   0  849920 210156  49500 R  99.7   0.9  62:40.28 php-fpm8.2
  97677 cezar     20   0  928264 243544  80036 R  99.3   1.0  70:59.62 php-fpm8.2
  97678 cezar     20   0  857808 250836  83868 R  99.3   1.0  70:28.52 php-fpm8.2
  98536 cezar     20   0  851968 211564  49500 R  99.0   0.9  63:13.34 php-fpm8.2
  98563 cezar     20   0  847872 206700  49504 R  97.4   0.8  62:27.47 php-fpm8.2
  98535 cezar     20   0  851968 210292  49500 R  96.7   0.9  63:23.76 php-fpm8.2
  21241 www-data  20   0 2014636  25264   7552 S   2.6   0.1   0:25.69 apache2
  89741 root      20   0       0      0      0 I   2.6   0.0   0:01.04 kworker/3:2-mm_percpu_wq
  39255 www-data  20   0   57988  13656   7352 S   0.7   0.1   1:47.86 nginx
    509 root      20   0 1287860  24932  11300 S   0.3   0.1   2:34.31 fail2ban-server
    512 root      20   0   82780   3740   3380 S   0.3   0.0   0:02.68 irqbalance
  74610 root      20   0   10968   4580   3540 S   0.3   0.0   1:41.31 htop
TOTAL FILES: 513968
TOTAL HITS: 0
TOTAL CLEANED: 0
Linux Malware Detect v1.6.5 < [email protected] >
See what the php-fpm procs have open, eg:
lsof -p 98564
Replacing that PID with a current one
COMMAND     PID  USER   FD   TYPE             DEVICE SIZE/OFF     NODE NAME
php-fpm8. 32419 cezar  cwd    DIR                8,3     4096 18219116 /home/cezar/web/xx-android.com/public_html
php-fpm8. 32419 cezar  rtd    DIR                8,3     4096        2 /
php-fpm8. 32419 cezar  txt    REG                8,3  5664328 13765749 /usr/sbin/php-fpm8.2
php-fpm8. 32419 cezar  DEL    REG                0,1              5142 /dev/zero
php-fpm8. 32419 cezar  DEL    REG                0,1              5140 /dev/zero
php-fpm8. 32419 cezar  mem    REG                8,3   309600 14156195 /usr/lib/x86_64-linux-gnu/libnss_systemd.so.2
php-fpm8. 32419 cezar  mem    REG                8,3   118480 14159955 /usr/lib/x86_64-linux-gnu/libzip.so.4.0
php-fpm8. 32419 cezar  mem    REG                8,3    96520 15734181 /usr/lib/php/20220829/zip.so
php-fpm8. 32419 cezar  mem    REG                8,3    96416 14160335 /usr/lib/x86_64-linux-gnu/libexslt.so.0.8.20
php-fpm8. 32419 cezar  mem    REG                8,3   264632 14160336 /usr/lib/x86_64-linux-gnu/libxslt.so.1.1.34
php-fpm8. 32419 cezar  mem    REG                8,3    39176 15734180 /usr/lib/php/20220829/xsl.so
php-fpm8. 32419 cezar  mem    REG                8,3    51464 15734179 /usr/lib/php/20220829/xmlwriter.so
php-fpm8. 32419 cezar  mem    REG                8,3    47368 15734178 /usr/lib/php/20220829/xmlreader.so
php-fpm8. 32419 cezar  mem    REG                8,3    35080 15731611 /usr/lib/php/20220829/tokenizer.so
php-fpm8. 32419 cezar  mem    REG                8,3    22792 15731610 /usr/lib/php/20220829/sysvshm.so
php-fpm8. 32419 cezar  mem    REG                8,3    14600 15731609 /usr/lib/php/20220829/sysvsem.so
php-fpm8. 32419 cezar  mem    REG                8,3    22792 15731608 /usr/lib/php/20220829/sysvmsg.so
php-fpm8. 32419 cezar  mem    REG                8,3   104712 15731607 /usr/lib/php/20220829/sockets.so
php-fpm8. 32419 cezar  mem    REG                8,3   342280 15734174 /usr/lib/php/20220829/soap.so
php-fpm8. 32419 cezar  mem    REG                8,3    63752 15734176 /usr/lib/php/20220829/simplexml.so
php-fpm8. 32419 cezar  mem    REG                8,3   200136 14156161 /usr/lib/x86_64-linux-gnu/libtinfo.so.6.3
php-fpm8. 32419 cezar  mem    REG                8,3   216376 14157680 /usr/lib/x86_64-linux-gnu/libedit.so.2.0.68
php-fpm8. 32419 cezar  mem    REG                8,3    39176 15731655 /usr/lib/php/20220829/readline.so
php-fpm8. 32419 cezar  mem    REG                8,3   620976 14159876 /usr/lib/x86_64-linux-gnu/libaspell.so.15.3.1
php-fpm8. 32419 cezar  mem    REG                8,3    26888 15734173 /usr/lib/php/20220829/pspell.so
php-fpm8. 32419 cezar  mem    REG                8,3   293128 15731604 /usr/lib/php/20220829/phar.so
php-fpm8. 32419 cezar  mem    REG                8,3   166152 15734170 /usr/lib/php/20220829/mysqli.so
php-fpm8. 32419 cezar  mem    REG                8,3   597344 14159947 /usr/lib/x86_64-linux-gnu/libonig.so.5.2.0
php-fpm8. 32419 cezar  mem    REG                8,3  1196960 15734169 /usr/lib/php/20220829/mbstring.so
php-fpm8. 32419 cezar  mem    REG                8,3   104712 15734168 /usr/lib/php/20220829/ldap.so
php-fpm8. 32419 cezar  mem    REG                8,3  3328472 14156961 /usr/lib/x86_64-linux-gnu/libicui18n.so.70.1
php-fpm8. 32419 cezar  mem    REG                8,3   592224 15734167 /usr/lib/php/20220829/intl.so
php-fpm8. 32419 cezar  mem    REG                8,3  2201936 14159804 /usr/lib/x86_64-linux-gnu/libfftw3.so.3.5.8
php-fpm8. 32419 cezar  mem    REG                8,3    55304 14159826 /usr/lib/x86_64-linux-gnu/liblqr-1.so.0.3.2
php-fpm8. 32419 cezar  mem    REG                8,3    43272 15731605 /usr/lib/php/20220829/posix.so
php-fpm8. 32419 cezar  mem    REG                8,3    35080 15734172 /usr/lib/php/20220829/pdo_mysql.so
php-fpm8. 32419 cezar  mem    REG                8,3    63880 14157604 /usr/lib/x86_64-linux-gnu/libicuio.so.70.1
php-fpm8. 32419 cezar  DEL    REG                0,1              5144 /dev/zero
php-fpm8. 32419 cezar  mem    REG                8,3    27072 14157628 /usr/lib/x86_64-linux-gnu/libcap-ng.so.0.0.0
php-fpm8. 32419 cezar  mem    REG                8,3   133200 14157681 /usr/lib/x86_64-linux-gnu/libaudit.so.1.0.0
php-fpm8. 32419 cezar  mem    REG                8,3    67736 14157033 /usr/lib/x86_64-linux-gnu/libpam.so.0.85.1
php-fpm8. 32419 cezar  mem    REG                8,3  1099432 13765825 /usr/lib/libc-client.so.2007e.0
php-fpm8. 32419 cezar  mem    REG                8,3   112904 15734166 /usr/lib/php/20220829/imap.so
php-fpm8. 32419 cezar  mem    REG                8,3    39384 14159828 /usr/lib/x86_64-linux-gnu/libltdl.so.7.3.1
php-fpm8. 32419 cezar  mem    REG                8,3    81640 14157687 /usr/lib/x86_64-linux-gnu/libXext.so.6.4.0
php-fpm8. 32419 cezar  mem    REG                8,3   390144 14159824 /usr/lib/x86_64-linux-gnu/liblcms2.so.2.0.12
php-fpm8. 32419 cezar  mem    REG                8,3  2817568 14159841 /usr/lib/x86_64-linux-gnu/libMagickCore-6.Q16.so.6.0.0
php-fpm8. 32419 cezar  mem    REG                8,3  1223088 14159843 /usr/lib/x86_64-linux-gnu/libMagickWand-6.Q16.so.6.0.0
php-fpm8. 32419 cezar  mem    REG                8,3    18696 15731606 /usr/lib/php/20220829/shmop.so
php-fpm8. 32419 cezar  mem    REG                8,3   465200 15731677 /usr/lib/php/20220829/imagick.so
php-fpm8. 32419 cezar  mem    REG                8,3    51464 15731602 /usr/lib/php/20220829/iconv.so
php-fpm8. 32419 cezar  mem    REG                8,3    22688 14160015 /usr/lib/x86_64-linux-gnu/libabsl_throw_delegate.so.20210324.0.0
php-fpm8. 32419 cezar  mem    REG                8,3    18656 14160012 /usr/lib/x86_64-linux-gnu/libabsl_strings_internal.so.20210324.0.0
php-fpm8. 32419 cezar  mem    REG                8,3    47472 14158037 /usr/lib/x86_64-linux-gnu/libmd.so.0.0.5
php-fpm8. 32419 cezar  mem    REG                8,3    26856 14159985 /usr/lib/x86_64-linux-gnu/libabsl_int128.so.20210324.0.0
php-fpm8. 32419 cezar  mem    REG                8,3   100672 14160017 /usr/lib/x86_64-linux-gnu/libabsl_time_zone.so.20210324.0.0
php-fpm8. 32419 cezar  mem    REG                8,3   121144 14160011 /usr/lib/x86_64-linux-gnu/libabsl_strings.so.20210324.0.0
php-fpm8. 32419 cezar  mem    REG                8,3    39224 14159967 /usr/lib/x86_64-linux-gnu/libabsl_demangle_internal.so.20210324.0.0
php-fpm8. 32419 cezar  mem    REG                8,3    22776 14159966 /usr/lib/x86_64-linux-gnu/libabsl_debugging_internal.so.20210324.0.0
php-fpm8. 32419 cezar  mem    REG                8,3    89096 14157603 /usr/lib/x86_64-linux-gnu/libbsd.so.0.11.5
php-fpm8. 32419 cezar  mem    REG                8,3    14536 14160003 /usr/lib/x86_64-linux-gnu/libabsl_raw_logging_internal.so.20210324.0.0
php-fpm8. 32419 cezar  mem    REG                8,3    14496 14160005 /usr/lib/x86_64-linux-gnu/libabsl_spinlock_wait.so.20210324.0.0
php-fpm8. 32419 cezar  mem    REG                8,3    22776 14159962 /usr/lib/x86_64-linux-gnu/libabsl_base.so.20210324.0.0
php-fpm8. 32419 cezar  mem    REG                8,3    18744 14159989 /usr/lib/x86_64-linux-gnu/libabsl_malloc_internal.so.20210324.0.0
php-fpm8. 32419 cezar  mem    REG                8,3    72232 14160016 /usr/lib/x86_64-linux-gnu/libabsl_time.so.20210324.0.0
php-fpm8. 32419 cezar  mem    REG                8,3    30952 14160013 /usr/lib/x86_64-linux-gnu/libabsl_symbolize.so.20210324.0.0
php-fpm8. 32419 cezar  mem    REG                8,3    14256 14160006 /usr/lib/x86_64-linux-gnu/libabsl_stacktrace.so.20210324.0.0
php-fpm8. 32419 cezar  mem    REG                8,3    26856 14159982 /usr/lib/x86_64-linux-gnu/libabsl_graphcycles_internal.so.20210324.0.0
php-fpm8. 32419 cezar  mem    REG                8,3    26800 14157064 /usr/lib/x86_64-linux-gnu/libXdmcp.so.6.0.0
php-fpm8. 32419 cezar  mem    REG                8,3    18720 14157701 /usr/lib/x86_64-linux-gnu/libXau.so.6.0.0
php-fpm8. 32419 cezar  mem    REG                8,3   485744 14159782 /usr/lib/x86_64-linux-gnu/libpcre.so.3.13.3
php-fpm8. 32419 cezar  mem    REG                8,3    59864 14160014 /usr/lib/x86_64-linux-gnu/libabsl_synchronization.so.20210324.0.0
php-fpm8. 32419 cezar  mem    REG                8,3    48152 14156976 /usr/lib/x86_64-linux-gnu/libnuma.so.1.0.0
php-fpm8. 32419 cezar  mem    REG                8,3   166504 14157054 /usr/lib/x86_64-linux-gnu/libxcb.so.1.1.0
php-fpm8. 32419 cezar  mem    REG                8,3   153904 14160094 /usr/lib/x86_64-linux-gnu/libgraphite2.so.3.2.1
php-fpm8. 32419 cezar  mem    REG                8,3  1277712 14159388 /usr/lib/x86_64-linux-gnu/libglib-2.0.so.0.7200.4
php-fpm8. 32419 cezar  mem    REG                8,3   526424 14160086 /usr/lib/x86_64-linux-gnu/libyuv.so.0.0.1807
php-fpm8. 32419 cezar  mem    REG                8,3   882848 14160084 /usr/lib/x86_64-linux-gnu/libgav1.so.0.0.1
php-fpm8. 32419 cezar  mem    REG                8,3  1316784 14159814 /usr/lib/x86_64-linux-gnu/libdav1d.so.5.1.1
php-fpm8. 32419 cezar  mem    REG                8,3 16071296 14159818 /usr/lib/x86_64-linux-gnu/libx265.so.199
php-fpm8. 32419 cezar  mem    REG                8,3   715104 14159816 /usr/lib/x86_64-linux-gnu/libde265.so.0.1.1
php-fpm8. 32419 cezar  mem    REG                8,3  5383376 14159812 /usr/lib/x86_64-linux-gnu/libaom.so.3.3.0
php-fpm8. 32419 cezar  mem    REG                8,3   141344 14159832 /usr/lib/x86_64-linux-gnu/libdeflate.so.0
php-fpm8. 32419 cezar  mem    REG                8,3    66568 14159821 /usr/lib/x86_64-linux-gnu/libjbig.so.0
php-fpm8. 32419 cezar  mem    REG                8,3  1306280 14156917 /usr/lib/x86_64-linux-gnu/libX11.so.6.4.0
php-fpm8. 32419 cezar  mem    REG                8,3   298776 14159802 /usr/lib/x86_64-linux-gnu/libgomp.so.1.0.0
php-fpm8. 32419 cezar  mem    REG                8,3    30936 14156174 /usr/lib/x86_64-linux-gnu/libuuid.so.1.3.0
php-fpm8. 32419 cezar  mem    REG                8,3   194872 14157751 /usr/lib/x86_64-linux-gnu/libexpat.so.1.8.7
php-fpm8. 32419 cezar  mem    REG                8,3   108864 14158000 /usr/lib/x86_64-linux-gnu/libfribidi.so.0.4.0
php-fpm8. 32419 cezar  mem    REG                8,3   844624 14160097 /usr/lib/x86_64-linux-gnu/libharfbuzz.so.0.20704.0
php-fpm8. 32419 cezar  mem    REG                8,3   137464 14160091 /usr/lib/x86_64-linux-gnu/libavif.so.13.0.0
php-fpm8. 32419 cezar  mem    REG                8,3   530624 14159819 /usr/lib/x86_64-linux-gnu/libheif.so.1.12.0
php-fpm8. 32419 cezar  mem    REG                8,3   432688 14159833 /usr/lib/x86_64-linux-gnu/libwebp.so.7.1.3
php-fpm8. 32419 cezar  mem    REG                8,3   551080 14159835 /usr/lib/x86_64-linux-gnu/libtiff.so.5.7.0
php-fpm8. 32419 cezar  mem    REG                8,3    80800 14160101 /usr/lib/x86_64-linux-gnu/libXpm.so.4.11.0
php-fpm8. 32419 cezar  mem    REG                8,3    63480 14160093 /usr/lib/x86_64-linux-gnu/libimagequant.so.0
php-fpm8. 32419 cezar  mem    REG                8,3   522960 14159822 /usr/lib/x86_64-linux-gnu/libjpeg.so.8.2.2
php-fpm8. 32419 cezar  mem    REG                8,3   813128 14159083 /usr/lib/x86_64-linux-gnu/libfreetype.so.6.18.1
php-fpm8. 32419 cezar  mem    REG                8,3   298120 14159810 /usr/lib/x86_64-linux-gnu/libfontconfig.so.1.12.0
php-fpm8. 32419 cezar  mem    REG                8,3    26616 14160099 /usr/lib/x86_64-linux-gnu/libraqm.so.0.700.0
php-fpm8. 32419 cezar  mem    REG                8,3   235592 14158302 /usr/lib/x86_64-linux-gnu/libpng16.so.16.37.0
php-fpm8. 32419 cezar  mem    REG                8,3   418088 14160103 /usr/lib/x86_64-linux-gnu/libgd.so.3.0.11
php-fpm8. 32419 cezar  mem    REG                8,3   112904 15734165 /usr/lib/php/20220829/gd.so
php-fpm8. 32419 cezar  mem    REG                8,3    71944 15731600 /usr/lib/php/20220829/ftp.so
php-fpm8. 32419 cezar  mem    REG                8,3  7153984 15731599 /usr/lib/php/20220829/fileinfo.so
php-fpm8. 32419 cezar  mem    REG                8,3   182536 15731598 /usr/lib/php/20220829/ffi.so
php-fpm8. 32419 cezar  mem    REG                8,3    96520 15731597 /usr/lib/php/20220829/exif.so
php-fpm8. 32419 cezar  mem    REG                8,3   203016 15734175 /usr/lib/php/20220829/dom.so
php-fpm8. 32419 cezar  mem    REG                8,3    47688 14158312 /usr/lib/x86_64-linux-gnu/libffi.so.8.1.0
php-fpm8. 32419 cezar  mem    REG                8,3    68552 14160434 /usr/lib/x86_64-linux-gnu/libresolv.so.2
php-fpm8. 32419 cezar  mem    REG                8,3    22600 14158314 /usr/lib/x86_64-linux-gnu/libkeyutils.so.1.9
php-fpm8. 32419 cezar  mem    REG                8,3    92312 14157085 /usr/lib/x86_64-linux-gnu/libtasn1.so.6.6.2
php-fpm8. 32419 cezar  mem    REG                8,3  1285888 14158226 /usr/lib/x86_64-linux-gnu/libp11-kit.so.0.3.0
php-fpm8. 32419 cezar  mem    REG                8,3   141664 14158323 /usr/lib/x86_64-linux-gnu/libbrotlicommon.so.1.1.0
php-fpm8. 32419 cezar  mem    REG                8,3   105392 14156226 /usr/lib/x86_64-linux-gnu/libsasl2.so.2.0.25
php-fpm8. 32419 cezar  mem    REG                8,3    52016 14156260 /usr/lib/x86_64-linux-gnu/libkrb5support.so.0.1
php-fpm8. 32419 cezar  mem    REG                8,3    18504 14156267 /usr/lib/x86_64-linux-gnu/libcom_err.so.2.1
php-fpm8. 32419 cezar  mem    REG                8,3   182864 14156256 /usr/lib/x86_64-linux-gnu/libk5crypto.so.3.1
php-fpm8. 32419 cezar  mem    REG                8,3   827936 14156263 /usr/lib/x86_64-linux-gnu/libkrb5.so.3.3
php-fpm8. 32419 cezar  mem    REG                8,3   526896 14158248 /usr/lib/x86_64-linux-gnu/libgmp.so.10.4.1
php-fpm8. 32419 cezar  mem    REG                8,3   281000 14157590 /usr/lib/x86_64-linux-gnu/libnettle.so.8.4
php-fpm8. 32419 cezar  mem    REG                8,3   289800 14157052 /usr/lib/x86_64-linux-gnu/libhogweed.so.6.4
php-fpm8. 32419 cezar  mem    REG                8,3  2000320 14157654 /usr/lib/x86_64-linux-gnu/libgnutls.so.30.31.0
php-fpm8. 32419 cezar  mem    REG                8,3  1743016 14157022 /usr/lib/x86_64-linux-gnu/libunistring.so.2.2.0
php-fpm8. 32419 cezar  mem    REG                8,3    51536 14158383 /usr/lib/x86_64-linux-gnu/libbrotlidec.so.1.1.0
php-fpm8. 32419 cezar  mem    REG                8,3    63992 14156176 /usr/lib/x86_64-linux-gnu/liblber-2.5.so.0.1.13
php-fpm8. 32419 cezar  mem    REG                8,3   376512 14156198 /usr/lib/x86_64-linux-gnu/libldap-2.5.so.0.1.13
php-fpm8. 32419 cezar  mem    REG                8,3   338648 14156265 /usr/lib/x86_64-linux-gnu/libgssapi_krb5.so.2.2
php-fpm8. 32419 cezar  mem    REG                8,3    75768 14158283 /usr/lib/x86_64-linux-gnu/libpsl.so.5.3.2
php-fpm8. 32419 cezar  mem    REG                8,3   441944 14157624 /usr/lib/x86_64-linux-gnu/libssh.so.4.8.7
php-fpm8. 32419 cezar  mem    REG                8,3   121864 14158310 /usr/lib/x86_64-linux-gnu/librtmp.so.1
php-fpm8. 32419 cezar  mem    REG                8,3   129096 14157063 /usr/lib/x86_64-linux-gnu/libidn2.so.0.3.7
php-fpm8. 32419 cezar  mem    REG                8,3   166288 14158041 /usr/lib/x86_64-linux-gnu/libnghttp2.so.14.20.1
php-fpm8. 32419 cezar  mem    REG                8,3   677656 14156145 /usr/lib/x86_64-linux-gnu/libcurl.so.4.7.0
php-fpm8. 32419 cezar  mem    REG                8,3    18696 15731601 /usr/lib/php/20220829/gettext.so
php-fpm8. 32419 cezar  mem    REG                8,3   125192 15734164 /usr/lib/php/20220829/curl.so
php-fpm8. 32419 cezar  mem    REG                8,3    39176 15731595 /usr/lib/php/20220829/calendar.so
php-fpm8. 32419 cezar  mem    REG                8,3    74848 14157066 /usr/lib/x86_64-linux-gnu/libbz2.so.1.0.4
php-fpm8. 32419 cezar  mem    REG                8,3    14600 15731596 /usr/lib/php/20220829/ctype.so
php-fpm8. 32419 cezar  mem    REG                8,3    30984 15734163 /usr/lib/php/20220829/bz2.so
php-fpm8. 32419 cezar  mem    REG                8,3    92424 15731676 /usr/lib/php/20220829/apcu.so
php-fpm8. 32419 cezar  mem    REG                8,3    59656 15734177 /usr/lib/php/20220829/xml.so
php-fpm8. 32419 cezar  mem    REG                8,3   133384 15731603 /usr/lib/php/20220829/pdo.so
php-fpm8. 32419 cezar  mem    REG                8,3   239472 15734171 /usr/lib/php/20220829/mysqlnd.so
php-fpm8. 32419 cezar  mem    REG                8,3  1018920 15731648 /usr/lib/php/20220829/opcache.so
php-fpm8. 32419 cezar  mem    REG                8,3  5712208 13897352 /usr/lib/locale/locale-archive
php-fpm8. 32419 cezar  mem    REG                8,3    39176 15734162 /usr/lib/php/20220829/bcmath.so
php-fpm8. 32419 cezar  mem    REG                8,3   353616 13896713 /usr/lib/locale/C.utf8/LC_CTYPE
php-fpm8. 32419 cezar  mem    REG                8,3   125488 14156158 /usr/lib/x86_64-linux-gnu/libgcc_s.so.1
php-fpm8. 32419 cezar  mem    REG                8,3  2260296 14156168 /usr/lib/x86_64-linux-gnu/libstdc++.so.6.0.30
php-fpm8. 32419 cezar  mem    REG                8,3 29476472 14158285 /usr/lib/x86_64-linux-gnu/libicudata.so.70.1
php-fpm8. 32419 cezar  mem    REG                8,3   149760 14157060 /usr/lib/x86_64-linux-gnu/libgpg-error.so.0.32.1
php-fpm8. 32419 cezar  mem    REG                8,3  2062664 14158240 /usr/lib/x86_64-linux-gnu/libicuuc.so.70.1
php-fpm8. 32419 cezar  mem    REG                8,3  1296312 14157589 /usr/lib/x86_64-linux-gnu/libgcrypt.so.20.3.4
php-fpm8. 32419 cezar  mem    REG                8,3    39024 14156979 /usr/lib/x86_64-linux-gnu/libcap.so.2.44
php-fpm8. 32419 cezar  mem    REG                8,3   125152 14157003 /usr/lib/x86_64-linux-gnu/liblz4.so.1.9.3
php-fpm8. 32419 cezar  mem    REG                8,3   841808 14156969 /usr/lib/x86_64-linux-gnu/libzstd.so.1.4.8
php-fpm8. 32419 cezar  mem    REG                8,3   170456 14158066 /usr/lib/x86_64-linux-gnu/liblzma.so.5.2.5
php-fpm8. 32419 cezar  mem    REG                8,3  2220400 14160421 /usr/lib/x86_64-linux-gnu/libc.so.6
php-fpm8. 32419 cezar  mem    REG                8,3    35000 14157062 /usr/lib/x86_64-linux-gnu/libargon2.so.1
php-fpm8. 32419 cezar  mem    REG                8,3   355040 14158072 /usr/lib/x86_64-linux-gnu/libsodium.so.23.3.0
php-fpm8. 32419 cezar  mem    REG                8,3   108936 14157049 /usr/lib/x86_64-linux-gnu/libz.so.1.2.11
php-fpm8. 32419 cezar  mem    REG                8,3   637632 14158292 /usr/lib/x86_64-linux-gnu/libpcre2-8.so.0.11.2
php-fpm8. 32419 cezar  mem    REG                8,3  4455728 14157759 /usr/lib/x86_64-linux-gnu/libcrypto.so.3
php-fpm8. 32419 cezar  mem    REG                8,3   667864 14157760 /usr/lib/x86_64-linux-gnu/libssl.so.3
php-fpm8. 32419 cezar  mem    REG                8,3  1967384 14157027 /usr/lib/x86_64-linux-gnu/libxml2.so.2.9.14
php-fpm8. 32419 cezar  mem    REG                8,3   807936 14157896 /usr/lib/x86_64-linux-gnu/libsystemd.so.0.32.0
php-fpm8. 32419 cezar  mem    REG                8,3    34888 14158088 /usr/lib/x86_64-linux-gnu/libacl.so.1.1.2301
php-fpm8. 32419 cezar  mem    REG                8,3    80768 14157749 /usr/lib/x86_64-linux-gnu/libapparmor.so.1.8.2
php-fpm8. 32419 cezar  mem    REG                8,3   940560 14160424 /usr/lib/x86_64-linux-gnu/libm.so.6
php-fpm8. 32419 cezar  mem    REG                8,3    27002 14160687 /usr/lib/x86_64-linux-gnu/gconv/gconv-modules.cache
php-fpm8. 32419 cezar  mem    REG                8,3   240936 14157691 /usr/lib/x86_64-linux-gnu/ld-linux-x86-64.so.2
php-fpm8. 32419 cezar    0u   CHR                1,3      0t0        5 /dev/null
php-fpm8. 32419 cezar    1u   CHR                1,3      0t0        5 /dev/null
php-fpm8. 32419 cezar    2u   CHR                1,3      0t0        5 /dev/null
php-fpm8. 32419 cezar    3ur  REG                8,3        0 18481165 /tmp/.ZendSem.gI4OiI (deleted)
php-fpm8. 32419 cezar    4u  unix 0xffff8e6791233fc0      0t0   104684 type=STREAM
php-fpm8. 32419 cezar    5u  unix 0xffff8e6ac5371540      0t0   112699 /run/php/php8.2-fpm-xx-android.com.sock type=STREAM
php-fpm8. 32419 cezar    6u  unix 0xffff8e678863a640      0t0   112700 type=STREAM
php-fpm8. 32419 cezar   12u  unix 0xffff8e6791230440      0t0   104701 /run/php/php8.2-fpm-xx-android.com.sock type=STREAM
root@vmi2064664:~#
Nothing obvious there. Sorry but I don’t think there’s much I can do without looking directly.
I’d suggest hiring a server expert at this point to take a look
I disabled the W3 Total Cache plugin and i see that things go to normal, i don`t have any clue why
