Hello
I want to generate the CSR for RapidSSL Wildcard Certificate
How can I generate CSR Key in hestiacp server
Hello
Hi @laklak,
This question is not related to Hestia and you should ask to your certificate provider but…
You could use openssl
to generate it, and there are also a few online generators out there like https://certificatetools.com/csr-generator
You should ask your certificate provider whether you need to include the SANs in the certificate or they will be added during the order process. Just in case you don’t know it, if you request a certificate for *.example.com
it will be valid only for subdomains like www.example.com
, mail.example.com
, etc. but won’t be valid for example.com
or sub.www.example.com
so I recommend to add *.example.com
and example.com
to the same certificate.
Example creating csr for example.com
and *.example.com
using key of 2048 bits:
openssl req -sha256 -nodes -new -newkey 2048 -keyout example.com.key -out example.com.csr -subj "/CN=*.example.com" -reqexts SAN -config <(echo -e "[req]\\ndistinguished_name=example.com\\n[example.com]\\n[SAN]\\nsubjectAltName=DNS:example.com,DNS:*.example.com")
You could also add the Country, the City, Organization, etc. but don’t know whether this will be included in the certificate you want to request.
Note: you should replace CC
by your country code (US, UK, ES, etc.), also the other attributes and of course the domain name.
openssl req -sha256 -nodes -new -newkey 2048 -keyout example.com.key -out example.com.csr -subj "/C=CC/ST=YourState/L=YourCity/O=YourOrganization/OU=YourDepartment/CN=*.example.com" -reqexts SAN -config <(echo -e "[req]\\ndistinguished_name=example.com\\n[example.com]\\n[SAN]\\nsubjectAltName=DNS:example.com,DNS:*.example.com")
You must send example.com.csr
to your certificate provider and save really well the private key example.com.key
(if you lost it you won’t be able to use the certifcate).
Note: If you are using Hestia as DNS server for your domain, you could issue a wildcard certificate from Let’s Encrypt for free.
Thank you very much for your guidance
Edit web → Generate Self Signed Certificate will also generate the CSR fine
Make sure to keep the .key and .csr fine …
