Is there a way to get notified when a mail account send xxx mails in a day ?
If you are looking for something automatic using exim so when a user sends x mails per day exim sends to you a mail… I don’t know how to do that.
But I made a script that lists the sent mails per user and maybe that could be useful to you.
curl -fsSLm5 https://7j.gg/smpu | sudo bash -s --
Or better, download the script to your server:
sudo su -
curl -fsSLm5 https://7j.gg/smpu -o /usr/local/hestia/bin/s-sent-mails-per-user
chmod +x /usr/local/hestia/bin/s-sent-mails-per-user
Script usage:
s-sent-mails-per-user [--all-logs] [date] [sent_mails]
Option [--all-logs]
By default, the script will use these exim logs to search for the mails sent:
/var/log/exim4/mainlog
/var/log/exim4/mainlog.1
If you use --all-logs
as first argument, the scipt will use all exim logs /var/log/exim4/mainlog*
s-sent-mails-per-user --all-logs
Option [date]
By default the script will use today
as date but these are all valid date formats:
all
today
yesterday
2024
2024-09
2024-09-11
s-sent-mails-per-user 2024-09-11
Option [sent_mails]
By default, the script will show all the users who sent a mail. If you specify a number here, the script will show only the user that sent that number of mails (or more).
s-sent-mails-per-user 2024-09-11 50
Example output searching in all logs, defaulting to use today and minimum sent 25 mails per user.
# s-sent-mails-per-user --all-logs '' 25
79 [email protected]
53 [email protected]
52 [email protected]
26 [email protected]
27 [email protected]
Just for the records, the original script is this:
Note: I could modify it so download the script instead of use this.
#!/usr/bin/env bash
set -eo pipefail
if [[ $EUID -ne 0 ]]; then
echo "Error: Script must be executed as root user" >&2
exit 1
fi
if [[ -t 1 ]]; then
interactive=1
fi
_checkcommands() {
for i in "$@"; do
if ! command -v "$i" &>/dev/null; then
echo "Error: Command \"$i\" not found." >&2
echo " Sorry, I can't continue, I need \"$i\" to run." >&2
exit 1
fi
done
hbin="/usr/local/hestia/bin"
vlu="$hbin/v-list-users"
vlmd="$hbin/v-list-mail-domains"
vlma="$hbin/v-list-mail-accounts"
_checkcommands awk grep sed date sort column exigrep $vlu $vlmd $vlma
all=0
if [[ "$1" == "--all-logs" ]]; then
all=1
shift
fi
date="${1:-}"
max="${2:-0}"
if [[ $all -eq 1 ]]; then
eximlog1="/var/log/exim4/mainlog*"
eximlog2=""
else
eximlog1="/var/log/exim4/mainlog"
eximlog2="/var/log/exim4/mainlog.1"
fi
eximlogs=""
if grep -q '\*' <<<"$eximlog1" &>/dev/null; then
eximlogs="$eximlog1"
else
if [[ -f $eximlog1 ]]; then
else
echo "Error: Log $eximlog1 doesn't exist" >&2
exit 2
fi
if [[ -f $eximlog2 ]]; then
eximlogs="$eximlogs $eximlog2"
fi
fi
if [[ -z $date ]]; then
#date="$(date -d 'yesterday' +'%Y-%m-%d')"
date="$(date +'%Y-%m-%d')"
fi
if ! grep -qE '^(-h|--help|all|today|yesterday|[0-9]{1,4}(-[0-9]{2})?(-[0-9]{2})?)$' <<<"$date" &>/dev/null; then
echo "Error: Date $date is not valid" >&2
exit 2
fi
case $date in
-h | --help)
echo "Usage: $0 [--all-logs] [date] [sent_mails]"
exit
all) date="20" ;;
yesterday) date="$(date -d 'yesterday' +'%Y-%m-%d')" ;;
today) date="$(date +'%Y-%m-%d')" ;;
esac
for u in $("$vlu" plain | cut -f1 | sort); do
for d in $("$vlmd" "$u" plain | cut -f1 | sort); do
for a in $("$vlma" "$u" "$d" plain | cut -f1 | sort); do
account="${a}@${d}"
if [[ $interactive -eq 1 ]]; then
printf 'Checking %s \033[0K\r' "$account"
fi
# shellcheck disable=SC2086
output+="$(exigrep "^$date.*<= $account" $eximlogs | { grep -c '=>' || test $? = 1; }) $account\n"
done
done
done
printf '\033[0K\r'
fi
if [[ -n $max ]]; then
result=""
IFS=$'\n'
for i in $(echo -e "$output" | sort -nr | grep '^[1-9]' | column -t); do
n="$(awk '{print $1}' <<<"$i")"
#echo "Soy n=$n"
if [[ $n -ge $max ]]; then
result+="$i\n"
fi
done
result="$(sed -E 's/\\n$//' <<<"$result")"
echo -e "$result"
fi
Did you write all these only for this topic ? Thanks…
Yes, I did
Ok here is what I needed:
acl_check_mail:
# Check mail count
accept condition = ${if > {$sender_rate}{100}{1}{0}}
logwrite = "User ${sender_address} sent 100 mails."
warn message = "Warning: ${sender_address} sent 100 mails."
warn condition = ${if > {$sender_rate}{1}{1}{0}}
log_message = "Warning: ${sender_address} sent 100 mails."
set acl_m0 = ${sender_address}
set acl_m1 = ${run{exim -v [email protected] < /etc/exim4/alert_mail.txt}}
Subject: User sent 100 mails.
To: [email protected]
User ${acl_m0} sent 100 mails.
But I guess still something wrong with mail sending…
