Hello, community! I installed Hestia with mail support. I am able to send and receive emails. But emails from gmail do not come to my server. I mean they come, but do not apperas in mailbox.
Here Log:
2024-01-18 11:26:28 1rQQXU-000sAs-6h <= [email protected] H=localhost (webmail.mydomain.us) [127.0.0.1] P=esmtpa A=dovecot_login:[email protected] S=584 [email protected]
2024-01-18 11:26:29 1rQQXU-000sAs-6h H=gmail-smtp-in.l.google.com [172.253.63.26] TLS error on connection (recv): The TLS connection was non-properly terminated.
2024-01-18 11:26:29 1rQQXU-000sAs-6h => [email protected] R=dnslookup T=remote_smtp H=gmail-smtp-in.l.google.com [172.253.63.26] X=TLS1.3:ECDHE_X25519__ECDSA_SECP256R1_SHA256__AES_256_GCM:256 CV=yes K C="250 2.0.0 OK t3-20020a0cde03000000b006818ceccdfbsi1157846qvk.167 - gsmtp"
2024-01-18 11:26:29 1rQQXU-000sAs-6h Completed
Microsoft works fine.
Please help me if somebody had same problem. Thank a lot!
eris
January 18, 2024, 1:41pm
2
This log is for outgoing mail…
This is from /var/log/exim4/mainlog. I tested , and log apears on receiving.
Now tested from microsoft, and i see rejected log:
H=mail-co1nam11on2091.outbound.protection.outlook.com (NAM11-CO1-obe.outbound.protection.outlook.com) [40.107.220.91] F=<[email protected] > rejected RCPT <[email protected] >: Rejected because 40.107.220.91 is in a black list at bl.spamcop.net
@eris I removed spam check. So for microsoft i can send and i can receive emails. But for Gmail i have problems with receiving =(
2024-01-18 15:41:01 1rQUVo-0011aD-R2 H=gmail-smtp-in.l.google.com [142.251.163.26] TLS error on connection (recv): The TLS connection was non-properly terminated.
How can i fix this ? Thank you a lot !
eris
January 18, 2024, 4:08pm
6
Do you receive back the emails that you send in Gmail. If so check the return message the usually provide more info…
Should not matter as see it al lot of times…
@eris Hello =)
I have response from google:
TLS Negotiation failed: FAILED_PRECONDITION: starttls error (71): 6509966221312:error:10000417:SSL routines:OPENSSL_internal:SSLV3_ALERT_ILLEGAL_PARAMETER:third_party/openssl/boringssl/src/ssl/tls_record.cc:592:SSL alert number 47
eris
January 19, 2024, 3:35pm
8
Make sure the hostname has a valid hostname and certificate it should work fine…
