Going to the default hostname opens wordpress
Hi all,
First timer here. Could someone please point me in the right direction? I accidentally quick-installed wordpress on the hestiacp’s default hostname (cpl.“domain”.com) so instead of going to the control panel, it defaults to wordpress set up - how can i return it back to where its supposed to go?
Thank you in advance.
Have you tried accessing your panel on port 8083? (e.g. cpl.example.com:8083)
I did but because the url as an ssl cert, it defaults to 443, i can only access it via the local_ip_address:8083
