Hello everyone, is it advisable to grant sudo privileges to an “admin” user from HestiaCP and manage website directories? Will I still be restricted by chroot? I’m asking because I want to disable root login without creating a separate user with identical permissions.
Create a new user that does not exists in Hestia and grant that user sudo permissions
That’s what I don’t want to do ![]()
Granting sudo permissions to the admin user would also mean with php you can run
exec(‘sudo apt remove nginx’);
Yes, I understand. However, what if I avoid hosting any websites using the “admin” account ( Except for HestiaCP ) and instead use different accounts to manage websites? Too many accounts, im trying to optimise it.
How could i access a chrooted directories with sudo account ? i saw this in sshd config:
# Hestia SFTP Chroot
Match User sftp_dummy99,warfish
ChrootDirectory %h
X11Forwarding no
AllowTCPForwarding no
ForceCommand internal-sftp
Are there any other security issues or errors that I should be aware of?
Thank you.
