I have strange problem and I can’t solve it. In GUI Configuration clamav-daemon is marked as down with red color, but if I check service status I can see is working.
systemctl status clamav-daemon
● clamav-daemon.service - Clam AntiVirus userspace daemon
Loaded: loaded (/lib/systemd/system/clamav-daemon.service; enabled; vendor preset: enabled)
Drop-In: /etc/systemd/system/clamav-daemon.service.d
└─extend.conf
Active: active (running) since Fri 2023-01-13 04:00:24 CET; 9h ago
Docs: man:clamd(8)
man:clamd.conf(5)
https://docs.clamav.net/
Process: 767 ExecStartPre=/bin/mkdir -p /run/clamav (code=exited, status=0/SUCCESS)
Process: 794 ExecStartPre=/bin/chown clamav /run/clamav (code=exited, status=0/SUCCESS)
Main PID: 796 (clamd)
Tasks: 2 (limit: 9442)
Memory: 1.6G
CGroup: /system.slice/clamav-daemon.service
└─796 /usr/sbin/clamd --foreground=true
I can restart service from GUI, but still showing red as down.
