Tell me how to set up srv recording from the picture), tried different methods well, everyone does not help.
Do you use hestia as your nameservers? Usualy you would have to build up a dns cluster for it.
Yes, it’s all set up. The question is how to create this SRV to record all the parameters from the picture to indicate?
As the photo does not work.
I would say this isnt directly related to hestia, but when I google it, I get the following suggestion:
Record: _sip._tls
Type: SRV
Priority: 100
IP or Value: 1 443 sipdir.online.lync.com
and
Record: _sipfederationtls._tcp
Type: SRV
Priority: 100
IP or Value: 1 5061 sipfed.online.lync.com
Source: Wie füge ich SRV Records für Office 365 hinzu? – Hilfe | one.com
PS: No need to write direct messages, we will answer in the forum as soon as we can .
