So, being stupid and with no recent backup, I just did something really stupid and I desperately need assistance.
HestiaCP was running 100% fine. And then I stupidly thought I could install VirtualMin/WebMin so that WHMCS could be used.
Well, my HestiaCP is still running - but not the important services:
no NGINX
no APACHE2
etc etc etc.
I “think” all of my sites are still there in /web but I can not see them from Hestia.
Am I totally screwed or is there some way to reinstate the ‘missing’ services that were obviously destroyed by installing Virtualmin. ?
I personaly don’t think that there is much to “help” (at least here over the forum), you need to check what exactly has be done from virtjualmin, what was installed, why your services doesnt start. Maybe the easier thing would be to take a backup from your accounts, reinstall the server or create a new hestia instance and restore the backups.
Also @eris is providing paid support from time to time, but the rate is 100 euro / hour due to european location - mine would be even higher .
