Hi! I have 1 such php:
<?php
ini_set('display_errors', '1');
ini_set('display_startup_errors', '1');
error_reporting(E_ALL);
if($_GET["okogk!ITK-g8klh"] != "afwergwe4t44tg34tg43g3434g34")
exit;
if(!isset($_GET["usercode"]) OR !isset($_GET["game"]) OR !isset($_GET["port"]) OR $_GET["game"] == "ts3")
exit;
$server_memory = exec("ps -aux | grep ".escapeshellcmd($_GET["port"])." | awk '{memory +=$4}; END {print memory }'");
$all_memory = exec("free -m | grep Mem | awk '{memory +=$2}; END {print memory }'");
print round($all_memory * $server_memory / 100) ;
This line does not run: $server_memory = exec(“ps -aux | grep “.escapeshellcmd($_GET[“port”]).” | awk ‘{memory +=$4}; END {print memory }’”);
Help
Thanks.
I would love to help you. How is this related to hestia?
I run this php through hestiacp. Then it doesn’t work. returns zero, and if it is on an apache2 + php server, it works.
And your hestia is running nginx + apache2 + php-fpm?
If you load a PHP file with a hello world does it work?
I am not sure if hestia allows the execution of bash scripts. It should be disabled for obvious reasons.
eris
December 21, 2021, 9:11pm
#5
Hestia doesn’t allow users to listen other users services.
Remove /etc/cron.d/hestia-proc and then reboot.
Yes.
yes.
Ok.
Thanks, for working!
Is it possible to work only for admin users? I think it provides security, so I don’t want to rule it out at all.
eris
December 21, 2021, 9:28pm
#8
admin user is threated also a normal user. Unless you run it as root
I mean, this is only called by 1 of my own pages so the customer can see their memory usage. The website that the customer sees runs from under the admin user if that helps.
