Help with DNSBL configuration on Exim (using BIND9, public resolvers)
Hi everyone,
I’d really appreciate some help. I’m running into issues with the DNSBL blocklists I’m using in Exim.
I suspect the problem is related to the fact that I’m relying on public DNS resolvers.
My /etc/resolv.conf currently looks like this:
# Dynamic resolv.conf(5) file for glibc resolver(3) generated by resolvconf(8)
#     DO NOT EDIT THIS FILE BY HAND -- YOUR CHANGES WILL BE OVERWRITTEN
# 127.0.0.53 is the systemd-resolved stub resolver.
# run "resolvectl status" to see details about the actual nameservers.
nameserver 1.1.1.1
nameserver 8.8.8.8
I’ve seen several threads recommending Unbound for DNSBL queries, but I already have BIND9 installed.
Has anyone here set this up with BIND9 and could share some guidance or a working example? I’m a bit hesitant to change things and accidentally break my mail flow.
Another (admittedly hacky) idea I had was to use some paid DNS resolvers that aren’t throttled or blocked by the DNSBL providers, but that feels like a band-aid.
Thanks in advance for any advice!
Spamhaus is the only provider that I know of who blocks open resolvers, and you should just go get a feed from them.
Try this once :
The fourth option worked. But since I’ll be using it for commercial purposes, I’ll have to pay, lol. Thank you very much. And sorry everyone, I hadn’t found this topic, lol
Ahh. In that case suggest using or setting up your own recursive DNS resolver over some other IP. Maybe on a VPS. Spamhaus is one brand I have started to hate soooo much since I started having issues. Took me so much time and stuff to sort it out.
I agree with you, I’ve been through so much hate these days lol. But thank you so much for helping me. For now, my decision is not to use them; I’m only using these at the moment:
bl.spamcop.net
b.barracudacentral.org
