We have released Hestia 1.10.10 and hestia-nginx 1.30.8.
We strongly recommend updating your server(s) to the latest versions.
Security
- Prevent phpMyAdmin SSO token forgery: sign tokens with a stronger signature and validate the host field; the 1.10.10 upgrade reinstalls the SSO endpoint with fresh keys, so existing SSO links stop working
- Grant MySQL database users access to the exact database name only;
_and%were treated as wildcards, so a grant could cover other databases, including themysqlsystem schema. The 1.10.10 upgrade replaces existing wildcard grants - Prevent directory names created by the user in the web statistics folder from being run as
sedcommands by root - Run the
v-dump-sitearchiver as the user, so a symlinkedpublic_htmlorwebdirectory can no longer add other files from the server to the archive - Validate the resolved document root path in
v-change-web-domain-docroot, and reject spaces, so the path can no longer break out of the web server configuration - Create the Let’s Encrypt ACME challenge files as the user instead of root
- Validate the FTP path in
v-add-web-domain-ftpand the cron time fields - Update hestia-nginx to 1.30.8 (CVE-2026-132779: excessive CPU usage with
ssl_early_data) #6036 - Create
smtp_relay.confwithout world read access, as it holds the relay password; the 1.10.10 upgrade fixes the permissions of existing files #6027 - Reject symlinks and create missing
auth.logfiles with mode 660 inv-log-user-login, and validate the login status argument #5991 - Optionally delete a user’s backups with
v-delete-user, so backups of former users are no longer kept forever (new BACKUPS argument, defaultno) #6045
Features
- Add support for PHP 8.6 #6017
Changes
- Use the Sury repositories instead of the deprecated Launchpad PPAs for Apache2 and PHP on Ubuntu; the 1.10.10 upgrade migrates existing Apache2 sources #6048
- Warn users whose password is still hashed with DES or MD5, which will no longer be supported for login #6039
- Update SnappyMail to 3.1.4 #6056
- Update Roundcube to 1.7.7 #6033
- Update all non-major dependencies and jsdom to v31 #6028 #6029
Bug fixes
- Test the php-fpm configuration before restarting it, so one broken pool no longer takes down every website using that PHP version, and a failing PHP version no longer prevents the restart of the others #6040
- Remove php-fpm pools left behind by a deleted user #6040
- Refuse to delete a PHP version with
v-delete-web-phpwhile web domains still use it or it is the default version #6043 - Update the system PHP alternative before rebuilding domains in
v-change-sys-php, so default-backend domains no longer stay on the previous PHP version #6038 - Keep “force SSL”, HSTS and the FastCGI cache when a web domain is suspended #6041 #6046
- Accept IPv6 addresses in
v-log-user-login, so IPv6 logins and failed logins are recorded #5991 - Create the user’s
confdirectory with mode 755, so DNS zones and mail load on systems with a hardened umask #6044 - Remove the restore of a missing backup from the queue instead of retrying it forever #6042
- Fix the per-domain Exim SMTP relay lookup for authenticated null-sender mail (read receipts, out-of-office replies); the 1.10.10 upgrade updates existing installations #5913
- Add
mail_compressto the Dovecot 2.4 globalmail_pluginssodoveadmworks with compressed mail; the 1.10.10 upgrade updates existing installations #6032 - Migrate PHP sources that still use the old
ppa.launchpad.nethostname to Sury; the 1.10.6 migration only matchedppa.launchpadcontent.net, so servers installed on Ubuntu 20.04 or older were missed #6052 - Fix web app quick installers failing when the server is behind NAT, by sending their requests to the internal IP instead of the public one #5994
- Fix
v-list-sys-infodetecting Debian and Ubuntu systems with an/etc/sysconfigdirectory as Amazon Linux, and the Hestia version leaking into the OS version #6050 - Fix
v-schedule-letsencrypt-domain#6031 - Fix the Flarum quick install for Flarum 2.x #6025
- Don’t build packages when a higher package revision is already available
