Hestia 1.10.5 release
[1.10.5] - Service Release
Security
  • Verify user role/session has not been tampered with and fix suspended users not always having their login disabled #5706
  • Fix v-unsuspend-user using the wrong POLICY_USER_VIEW_SUSPENDED comparison, so unsuspending a user did not always unlock their account #5711
  • Improve read-only/demo mode enforcement, closing bypasses via direct URLs (e.g. /add/cron/), open redirects, and the admin login-as flow #5688
  • Improve conf parsing and reserved-key handling to prevent injection via crafted config values #5698
Changes
  • Remove support for Debian 11 (Bullseye) #5654
  • Bump Quick Install app versions: Dolibarr, Drupal, Grav, Joomla, OpenCart, PrestaShop #5700
  • Bump hestia-php to 8.5.10 #5678
  • Bump OpenSSL to 3.5.8 #5658
  • Update PCRE to 10.48 #5673
  • Update Roundcube to 1.7.4 #5690
  • Bump File Manager to 7.16.2 #5695
  • Enhance backup detail pages by adding icons to item types #5679
  • Update dependencies #5666 #5693 #5694
  • Add missing tests for suspending users #5710
Fixes
  • Fix inverted database limit check condition that could block users from creating databases within their quota #5640
  • Fix phpMyAdmin SSO for remote databases and redirects to the wrong server #5454
  • Rename phpMyAdmin tempdir configuration to load it last #5655
  • Fix restic full restore to restore all objects and correct cron binary name #5709
  • Fix backup host setup passing $raw_password instead of $password for Backblaze B2 credentials #5697
  • Fix issues when running behind a NAT / reverse proxy setup #5689
  • Implement locking mechanism for Fail2Ban actions and firewall state, and fix raw IP CIDR handling #5699
  • Fix ProFTPd on Debian 13 and Ubuntu 26.04 #5677
  • Omit CN for domains longer than 64 characters when generating SSL certificates #5676
  • Fix Global SMTP relay password validation #5665
  • Validate empty database alias #5663
  • Fix Apache2 logrotate when webstats fails because the domain is suspended #5685
  • Fix “Rejected because” DNSBL message for existing Exim installations #5683
  • Fix action button icons overlapping text on mobile view #5680
Please update your servers
