Generated from SSH using v-generate-api-key, my admin account is 2FA’d, allowed IP list is 127.0.0.1(localhost). Every time my php script tries to create a new user with the API key, it says Authentication Failed.
Don’t provide username or password with autentication with api key
https://docs.hestiacp.com/admin_docs/api/rest_api.html#create-user-with-api-key
Yep, I didnt, just hst_hash, etc. Etc.
API should always skip 2FA checks any way
Did it contains an _ or - by accident. I know there are some issue in the past with it…
This the check.
Check /var/log/hestia/auth.log if you see something in there
Yes the API key did have an underscore. When I regenerated the new one didnt, but still gave the error
I am not able to debug on your server… I am using the api year without any issue. Try to look where is going wrong
So I have done a few things and it is “working” now, well, not really, whenever I try to test it just returns “2” and doesnt create the user.
Hmm I provided everything but last name, it is just blank, also is PAM regulation applied when creating users thru API?
