eris
April 6, 2023, 12:04pm
1
Due to an breaking update on Lets Encrypt API server that will go in effect in the next 2 weeks! We ask all users to update to the last version that just have been release.
opened 11:27AM - 06 Apr 23 UTC
closed 12:29PM - 06 Apr 23 UTC
bug
### Describe the bug
Due to changes in the api of Lets encrypt that hasn't im… plemented in Hestia 1.7.1 and below users may expect issues downloading SSL certificates from Lets Encrypt. The changes will go in affect on 24th April permanently how ever users may expect issues to be raised due some "tests" held in the up coming weeks
See: https://community.letsencrypt.org/t/enabling-asynchronous-order-finalization/193522
> April 10: 24 hours in Production
> April 14-17: a whole weekend in Production
> April 24: enabled permanently in Production
Following error will happen:
> Error: Let's Encrypt downloading signed cert failed status: (idn-tést.eu)
Resolution:
1. Upgrade Hestia to 1.7.2 or higher
2. Manually patch the issue your self #3442
Users that are using Debian Stretch or Ubuntu 16.04 should consider upgrading there servers (Or at least patch the changes listed in #3442
### Tell us how to replicate the bug
Enable Letsencrypt against staging server (or on the specified dates in production)
### Which components are affected by this bug?
Let's Encrypt SSL
### Hestia Control Panel Version
1.7.1 or before
### Operating system
N/A
### Log capture
_No response_
