Hestia 1.7.2 SSL Letsencrypt error on ubuntu aws ec2
Hi, I have managed to install Hestia 1.7.2 successfully on ubuntu aws ec2, however, I am facing challenges to acquire SSL from Letsencrypt.
The attached screenshot shows well known acme challenge failure error.
I am facing the error both on control panel subdomain as well as the newly setup main domain.
I have another question:
  1. Is there any limitation to number of certs for subdomains one can acquire from Letsencrypt?
  2. And can we acquire one certs for main domain and reuse it for all subdomain?
Yes 500 in a week
Yes if you get a wild card and use *.domain.com as alias + DNS from Hestia
But the error has nothing to do with any limits.
Follow the link in the error message and it should show a string if not there is some other things wrong…
Hi @eris, Thanks for your prompt response.
Unfortunately, I could not try this earlier to respond back to you.
I checked today and have two observations:
  1. My site <Domain.com> is returning the Server default “Success!
    Your new web server is ready to use.
    ” and not the Hestia default page with content as “
    This site is currently under construction.
    Please check back soon.
  2. root@:/home//web/<Domain.com>/public_html - I don’t see a .<.well-known> folder as expected by Letsencrypt http://www.domain.com/**.well-known**/acme-challenge/ak12TZ0oZDfeEx7P3jitPo6mSslQ3p0Ha6-FlD3yyyk: 404"
Please can you advise further
It seems my issue is related to Do not load website from public_html - #20 by erwin
Does it matter with which user we install the hestia panel?
Default user on my AWS is not root.
Do you have multiple ips assigned to the server?
No just one IP, however, I see the same IP twice on GUI dropdown. I have just one domain and one sub-domain for the panel.
Can you run v-list-sys-ips
root@host:/usr/local/hestia/data/templates/web/skel/public_html# cd $HESTIA/bin
root@host:/usr/local/hestia/bin# v-list-sys-ips
IP MASK NAT STATUS WEB DATE
172.31.33.203 255.255.240.0 shared 3 2023-04-13
172.31.39.79 255.255.240.0 shared 0 2023-04-13
172.31.33.203 - I have just unassigned this IP from the AWS EC2 config and rebooted the AWS instance.
Then I rebuild web domain as
172.31.33.203 → PUBLIC_IP
255.255.240.0
eth0
shared
3
admin
Now, on Hestia Panel under Network, I still see two local IPs pointing to same public IP. Unfortunately, I am unable to delete the one I could manage to delete from AWS EC2. Reason being 3 domains hosted on this local IP
v-rebuild-web-domain user domain
To make sure it updates…
And then try again
Then I rebuild web domain as v-rebuild-web-domain user domain
255.255.240.0
eth0
shared
3
admin
I manage to move two domains to the correct local IP.
Don’t know which one is the third domain as I have only two domains hosted.
I had transferred the ownership of HOST panel domain from default admin to a NEW USER created by me on HESTIA, is that stale record exists on the panel?
HOW is the data written in this file? Is it okay if I set it manually to Zero and attempt to delete the ips?
root@host:/usr/local/hestia/data/ips# cat 172.31.33.203
OWNER=‘admin’
STATUS=‘shared’
NAME=‘’
U_SYS_USERS=‘admin’
U_WEB_DOMAINS=‘1’
INTERFACE=‘eth0’
NETMASK=‘255.255.240.0’
NAT=PUBLIC_IP
TIME=‘23:08:34’
DATE=‘2023-04-13’
Yes that is fine
Manage to progress further. But a new error now .
I have also added *.domain.com as an alias on HESTIA domain field (www.domain.com was another alias I added earlier)
and have also a *.domain.com as an A and CNAME record on HESTIA DNS (with just A record it did not work, so I tried to create CNAME record as well) but still it does not work.
I have created a *.domain.com A type record with Domain registrar (I was getting a DNS record does not exist for *.domian.com) until I added this record.
New error is:
“Error: Let's Encrypt new auth status 400 (domain.com)”
You can’t use wildcards if you use your providers name server. You need to be using DNS provided by Hestia and the name servers should point to your Hestia server
I faced another error after fixing the DNS at domain provider to personal domain NS records and created A records at HESTIA for the NS subdomains.
This resolved the original error. However, I got auth status 400 error with Letsencrypt after this which got resolved after running the vlets*domain and v-letshost commands both for all domains and Hestia panel server subdomain.
Thank you so much for all help @eris.
