Hestia 1.8.2 installation error Debian 12
2023-07-21_12-55-14
Why packages are not downloaded to a folder /usr/local/hestia ?
tried to install many times, all the same
Thank you for downloading Hestia Control Panel! In a few moments,
we will begin installing the following components on your server:
   - NGINX Web / Proxy Server
   - Multi-PHP Environment
   - Bind DNS Server
   - Exim Mail Server + SpamAssassin
   - Dovecot POP3/IMAP Server
   - MariaDB Database Server
   - Vsftpd FTP Server
   - Firewall (iptables) + Fail2Ban Access Monitor
Would you like to continue with the installation? [Y/N]: Y
Installation backup directory: /root/hst_install_backups/210720231233
Installation log file: /root/hst_install_backups/hst_install-210720231233.log
[ * ] NGINX
[ * ] PHP
[ * ] MariaDB
[ * ] Hestia Control Panel
Updating currently installed packages, please wait...-
NOTE: This process may take 10 to 15 minutes to complete, please wait...
E: Unable to correct problems, you have held broken packages.
[ * ] Configuring system settings...
cp: cannot stat '/usr/local/hestia/install/deb/logrotate/httpd-prerotate/*': No such file or directory
[ * ] Configuring Hestia Control Panel...
cp: cannot stat '/usr/local/hestia/install/deb/sudo/admin': No such file or directory
chmod: cannot access '/etc/sudoers.d/admin': No such file or directory
cp: cannot stat '/usr/local/hestia/install/deb/logrotate/hestia': No such file or directory
ln: failed to create symbolic link '/usr/local/hestia/log': No such file or directory
touch: cannot touch '/usr/local/hestia/log/system.log': No such file or directory
touch: cannot touch '/usr/local/hestia/log/nginx-error.log': No such file or directory
touch: cannot touch '/usr/local/hestia/log/auth.log': No such file or directory
touch: cannot touch '/usr/local/hestia/log/backup.log': No such file or directory
chmod: cannot access '/usr/local/hestia/log': No such file or directory
chmod: cannot access '/var/log/hestia/*': No such file or directory
cp: cannot stat '/usr/local/hestia/install/common/packages': No such file or directory
sed: can't read /usr/local/hestia/data/packages/*.pkg: No such file or directory
cp: cannot stat '/usr/local/hestia/install/deb/templates': No such file or directory
cp: cannot stat '/usr/local/hestia/install/common/templates/web/': No such file or directory
cp: cannot stat '/usr/local/hestia/install/common/templates/dns/': No such file or directory
cp: cannot stat '/usr/local/hestia/install/common/templates/web/unassigned/index.html': No such file or directory
cp: cannot stat '/usr/local/hestia/install/common/templates/web/skel/document_errors/*': No such file or directory
cp: cannot stat '/usr/local/hestia/install/common/firewall': No such file or directory
cp: cannot stat '/usr/local/hestia/install/common/api': No such file or directory
[ * ] Configuring OpenSSL to improve TLS performance...
[ * ] Generating default self-signed SSL certificate...
hst-install-debian.sh: line 1309: /usr/local/hestia/bin/v-generate-ssl-cert: No such file or directory
[ * ] Adding SSL certificate to Hestia Control Panel...
sed: -e expression #1, char 3: unexpected `,'
sed: -e expression #1, char 1: unknown command: `,'
cp: cannot stat '/usr/local/hestia/install/deb/ssl/dhparam.pem': No such file or directory
[ * ] Enabling SFTP jail...
Error: can't enable sftp jail
What is your server ip?
Please send it via dm
Hii eris, gtsy!
IP: xx.xx.xx.xx
I don’t understand what is “dm”, maybe “pm”…
Direct message … Or Private message…
Your ip is not on the block list
What do you see when you run:
wget https://apt.hestiacp.com
Maybe the problem is here…
Yes. But why …
https://jira.mariadb.org/browse/MDEV-28397
Currently all mariadb .deb are build with libssl1.1 and liburing1, where Ubuntu 22.04 now shipping with libssl3 and liburing2 (as like as Debian experimental) only, making the installation failed. We need a new package for it.
I will try downgrading the mariadb version one by one until it works, I will write the result later
For debian 12 we install it from debian source instead of mariadb as they are not available yet…
OMG, Yes, really, source that install Hestia install OK!
This repo from MariaDB website can’t install
Thank you so much for your help!
