Hestia 1.9.1 failed because the control process exited with an error code
I’m trying to install the new version of hestia on ubuntu 22.04 oracle.
I created a new instance and ran apt update and apt ugrade.
During the installation I got this message:
[ * ] Configuring the Apache Web Server...
[ * ] Installing PHP 8.3...
[ * ] Configuring PHP-FPM 8.3...
The job for php8.3-fpm.service failed because the control process exited with an error code .
See “systemctl status php8.3-fpm.service” and “journalctl -xeu php8.3-fpm.service” for details.
Error: php-fpm failed to start
The installation log shows this error:
Processing triggers for php8.3-cli (8.3.16-1+ubuntu22.04.1+deb.sury.org+1) ...
Processing triggers for dovecot-core (1:2.3.16+dfsg1-3ubuntu2.4) ...
invoke-rc.d: policy-rc.d denied execution of restart.
Processing triggers for php8.3-fpm (8.3.16-1+ubuntu22.04.1+deb.sury.org+1) ...
invoke-rc.d: policy-rc.d denied executing restart.
WARNING: You are not enabling PHP 8.3 FPM by default.
NOTICE: To enable PHP 8.3 FPM on Apache2, do the following:
NOTICE: a2enmod proxy_fcgi setenvif NOTICE: a2enconf php8.3-fpm NOTICE:
You are seeing this message because you have the apache2 package installed.
Best thing it to build 1 from soure
Only replace:
./hst_autocompile.sh --all --noinstall --keepbuild ‘~localsrc’
with
./hst_autocompile.sh --hestia --noinstall --keepbuild ‘~localsrc’
It will save you 30 min waiting :slight_smile:
I will try this.
Thank you.
It worked perfectly here after building the installation packages.
Now during the installation it appears:
[ * ] Installing local package files...
    - hestia core package
    - hestia-php backend package (from apt)
    - hestia-nginx backend package (from apt)
I had to edit hst_autocompile.sh because it didn’t recognize the version of NODE.js installed in the latest version, as Building stopped.
I commented out the lines below and it worked:
#echo “Installing Node.js...”
#apt-get -qq update > /dev/null 2>&1
#apt -qq install -y nodejs > /dev/null 2>&1
nodejs_version=$(/usr/bin/node -v | cut -f1 -d'.' | sed 's/v//g')
#if [ “$nodejs_version” -lt 18 ]; then
# echo “Requires Node.js 18.x or higher”
# exit 1
#fi
After building I installed using:
We have released 1.9.2 :slight_smile:
Should work without all those steps
Very good !!!
For the installation to work, I had to delete some hestia installation folders, my domain user and also the hestia users.
