Hestia 1.9.7 released
Please update your server(s)
Version name changes
Due to the implementation for building ARM64 packages on X86-64 hardware the versions of hestia-nginx / hestia-php has been changed the format used for 1.10 and forward.
  • hestia-nginx-x.y.z-revision-os+release_architecture.deb
  • hestia-php-x.y.z-revision-os+release_architecture.deb
It has no effect on the working. Both “hestia” package and “hestia-web-terminal” will follow in the future.
Security
  • Unauthenticated Remote Code Execution via Session Deserialisation Mismatch in Web Terminal (GHSA-gh6f-9gpr-x9m2)
  • IP Address Spoofing via CF-Connecting-IP Header (GHSA-73p3-rqpv-59wx)
  • Cross-site Scripting (XSS) in Hestia Control Panel (GHSA-fg7j-gpvw-2m73)
  • Client to Root RCE via Newline Injection in v-add-cron-job and Eval Stdout Poisoning in parse_object_kv_list (GHSA-5fpv-c8rg-x6r3)
  • Systematic Second-Order Command Injection in Queue System Leading to Root RCE (GHSA-47mf-74xr-f8x9)
  • Root RCE via double eval() on user-controlled config data in parse_object_kv_list() (func/main.sh) (GHSA-w3mx-xq85-8qqc)
  • Low-privilege to root command execution via unescaped web.conf path fields evaluated by v-search-user-object (GHSA-cr7q-frhq-xw4v)
  • HestiaCP 1.9.6 — SQL Injection in Database Password (CWE-89) (GHSA-8w7m-g9c2-9q9p)
  • HestiaCP <= 1.9.6 Authenticated Admin Takeover (GHSA-fcq6-p8cj-xx3c)
Features
  • Add: JSON files can now be edited directly in the File Manager (#5342)
Bug fixes
  • Fix: Add validation for backup fields in v-schedule-user-restore (#5510)
  • Improve security by removing eval from search utilities (#5509)
  • Bump file manager to version 7.14.4 (#5508)
  • Secure database user creation / password change to prevent SQL injection (#5511)
  • Fix typo in $KEEP_MONTHLY on v-backup-user-restic (#5409)
  • Allow installation to continue when netplan config is missing (#5406)
  • Fix missing HESTIA variable by sourcing hestia.conf (#5433)
  • Check SFTP jail status before add/delete user jail operations (#5420)
  • Fix incorrect comment in web/add/mail/index.php (#5428)
  • Fix private key detection not being propagated to sftpc() (#5426)
  • Make v-extract-fs-archive fully non-interactive during extraction (#5436)
  • Fix if statement in installer (#5440)
  • Docs: Add mail cleanup guidance (#5371)
  • Bump Roundcube to version 1.6.17 (#5492)
