Hestia Backup/Restore automation
Hi all,
I have two Hestia instances the Cloud (ACTIVE) and the Primary (BACKUP). On the Primary instance, I have the PULL bash scripts, which pull the user’s data from the Cloud:
  • 1.) Go to the Cloud and make v-backup-users backup
  • 2.) Using for loop copy the .tar latest backups (exclude admin) from Cloud to Primary
  • 3.) Using for loop restore via v-restore-user
  • 4.) delete backups older than 1 day
All is working perfectly, but I noticed that my PRIMARY Hestia has bigger DISK usage since, for example, the mails that are deleted on the CLOUD, after restoring on the PRIMARY are not deleted, just new files are added + existing overwritten.
How can I solve this without using rysync --delete ?
You could sync the email using imapsync. That however is not a solution for the other user’s files.
Yeah, I was thinking of anyone tried to edit the v-restore-user script to adjust this?
Before restoring users from backups, I use this script to extract the names of the email accounts from latest backups and if the email account exists in the backup and in the system, I use doveadm to purge the mail account.
This is the script:
#!/usr/bin/env bash
set -o pipefail
if [[ $EUID -ne 0 ]]; then
    echo "Error: you must run the script as root" >&2
    exit 1
fi
backup_dir="/backup"
backups=$(for i in $(find "$backup_dir" -type f -name "*tar" | cut -f1 -d '.' | sort -u); do
    file="$(sed -E 's/^.*\///' <<<"$i" | cut -d '.' -f1)"
    find "$backup_dir" -type f -name "$file.*tar" | sort -n | tail -n1
done)
for fbackup in $backups; do
    user="$(echo "$fbackup" | cut -d '/' -f3 | cut -d '.' -f1)"
    if accounts="$(tar tf "$fbackup" 2>/dev/null | grep 'accounts.tar')"; then
        echo "Processing user $user"
        for account in $accounts; do
            domain="$(echo "$account" | cut -d'/' -f3)"
            if grep 'zst$' <<<"$account" &>/dev/null; then
                ztype='--zstd'
            else
                ztype='--gzip'
            fi
            if ! uacc="$(tar xOf "$fbackup" "$account" | tar t "$ztype" 2>/dev/null | grep '/$' | cut -d '/' -f1 | sort -u)"; then
                continue
            fi
            for email_user in $uacc; do
                echo "Purging $email_user@$domain"
                if [[ -d "/home/$user/mail/$domain/$email_user" ]]; then
                    echo "doveadm purge -u $email_user@$domain"
                    echo "doveadm expunge -u $email_user@$domain mailbox \"*\" all "
                else
                    echo "User $email_user does not exist"
                fi
                echo
            done
        done
    fi
done
As the script will purge all the mails of existing accounts, in above script it won’t run the doveadm commands, it will only show the commands that it would use. If you try the script and it shows the right accounts to be purged, edit the script and replace this:
by this:
doveadm purge -u "$email_user@$domain"
doveadm expunge -u "$email_user@$domain" mailbox "*" all
Thank you! Just implemented this, it was something that I wanted to have.
