Why not also include the installation of wordpress and other web files?
It is allready in Hestia for over 6 months…
And for Backups there should be no excuse for making them…
I mean about backup, when hestia make a backup is about system files, such as ssl, database and etc… but not include website files, so… why not? @eris
Is does. It only compressed in an .tar.zst or .tar.gz. it is located in /web/{domain} folder when you open the backup
I hate this .zst backups.
If someone needs to extract it at Windows, then use Peazip portable.
Great! thanks a lot
already did it and working great, thanks
Even better, ditch Windoze and be liberated!
You hate srsly fast backup speed? nevermind .
v-change-sys-config-value BACKUP_MODE gzip
Don’t see the issue
