ok, I see rainloop, but when I Add mail domain I see Roundcube as default. Where install rainloop as default for add mail domains?
PHP errors will be fixed in a next release… (1.4.1)
Would it be an easy process to go back to stable version once i install the beta version?
Am eager to try out the the SMTP relay functionality.
No, a downgrade is not possible. I would suggest to wait a bit, the release is planed for today - if there are no big show stoppers.
No probs. I guess I can wait for a day or two more. No harm in it.
Thanks for getting back
I have one question: if I install nginx+apache+php-fpm and hosting 3 sites, can I install one site for scheme nginx+php-fpm without apache on this server?
Yes you can how ever you have to copy the template you are using from php-fpm folder first. Also some features (Fast CGI Cache) may is not availble for you with out manual config.
end of wednesday. update on monday?
Today …
my friends and I left Vesta, there are so many fixes in the announcement! Looking forward to learning Hestia! THANK YOU!
p.s. we have already tried the beta. prepared all the backups, and everything works great. we sit and drool!
guys, thank you for your work! you make not only a good product, but also a good mood!
