NewGuy
1
How can i setup hestia panel under subdomain
I want have panel under hestia.domain_com
and also i want host my page under domain_com
Now i have installed hestia but access to it is using ip:port but i want make access using hestia.domain_com
It is possible and how?
eris
2
Setup Hestia with hestia.domain.com
Login after install → Create new user → Add webdomain → domain.com
NewGuy
3
I think I misspelled my problem.
When I install hestia I set hesta.domain.com during installation.
But that subdomain dont work: I see “Success! Your new web server is ready to use.” but not hestia dashboard
SSL work somehow when i access to panel using ip:8083 i geting ssl connection and that cert is created for hestia.domain.com
NewGuy
4
I find something (but i don’t know it is correct)
In /etc/nginx/conf.d/
I create hestia.conf
server {
listen [ip]:443 ssl http2;
server_name hestia.domain.com;
location / {
proxy_pass https://[ip]:8083;
and things start works but when I try login I see error about CSRF
i run
v-change-sys-config-value 'POLICY_CSRF_STRICTNESS' '0'
and now all works!
But still, I have a question, How dangerous is that command what I run
eris
5
It prevent some small CSRF abuse if it still possible it is currently almost impossible to abuse this behaviour.
The config you posted will disable Let encrypt from working and https://domain.com/phpmyadmin/ will not be working any more…
I will create later on a template that keeps phpmyadmin and letsencrypt working how ever I have other things to attend first
NewGuy
6
I take a while and create that config
server {
listen IP;
server_name hestia.DOMAIN.COM;
return 301 https://$host$request_uri;
server {
listen IP:443 ssl http2;
location / {
proxy_pass https://127.0.0.1:8083;
location /phpmyadmin/ {
alias /usr/share/phpmyadmin/;
index index.html index.php;
location ~ /(libraries|setup|templates|locale|sql)/ {
deny all;
return 404;
location ~ /(.+\.(json|lock|md)) {
deny all;
return 404;
location ~ ^/phpmyadmin/(.*\.php)$ {
alias /usr/share/phpmyadmin/$1;
fastcgi_pass 127.0.0.1:9000;
fastcgi_index index.php;
include fastcgi_params;
fastcgi_param SCRIPT_FILENAME $request_filename;
location /phpmyadmin/(.+\.(jpg|jpeg|gif|css|png|js|ico|html|xml|txt))$ {
root /usr/share/phpmyadmin/;
Works for me (but if you have any ideas what I can do better I waiting. I don’t feel super experienced)
Erekyu
7
I am going to give this a shot for my subdomain wish me luck!
