Hestia Dashboard v.2.1.1
Updated the Dashboard addon and added new color themes and a whole new theme called panel GitHub - ALS-Sanbox/Hestia_Dashboard: This is a dashboard switcher using CLI to switch dashboard themes. · GitHub
It’s not a bad solution, but I think it would be much more useful to integrate the web interface with WordFence CLI, for example. For scanning and cleaning websites from viruses. Such a solution would be priceless. And if it worked through the web interface, even more so. This is just an example.
Something similar existed before, but via Docker, which was quite inconvenient.
But that’s just my opinion!
well, that seems out of scope for just a dashboard addon – I am just changing the look and feel of the dashboard that is it now if you want to add in other options for your users you can modify the dashboard yourself to have the button to go to your plugin page that has all the stuff needed to work with Wordfence etc – or just use wordfence in your wordpress install
I’m not against it. Someone might find your solution useful. I suggested the idea for someone who can implement the WordFence solution.
