Hello, can someone write me how to make DNS cluster with HestiaCP?
I don’t want to experiment, so copy/paste commands would be nice.
Thanks!
Thanks!
Hi @Amadex,
You can use the following command:
v-add-remote-dns-host subdns.example.com 8083 admin password
@eris thanks
But I’ve saw this https://tweenpath.net/vesta-set-master-slave-dns-cluster/
and the part there makes my head to think, is this needed?
Now Enable Zone Transfer
enable AXFR (Zone Transfer) in Bind
Replace following string in the named configuration file:allow-transfer {“none”;};
withallow-transfer { XXX.YYY.ZZZ.111; XXX.YYY.ZZZ.222; };
also-notify { XXX.YYY.ZZZ.111; XXX.YYY.ZZZ.222; };
If you use method with v-add-remote-dns-host no this is done by default if you update your dns records.
How ever if you want to sync with a non Hestia / Vestia server your option is required.
This is how goes the order right?
Also the NS & A ns2. record in Server1 should be updated to Server2 IP too?
Correct?
This should work
For those who only have one VPS, there are free services such as FreeDNS which offers “One IPv4 Secondary DNS Server” or Hurricane Electric which offers up to “Four IPv4/IPv6 Secondary DNS Servers”.
I have them 13, with all differents locations
@eris one more question (I know that I’m boring but it will help others later): Why is the default PHP CLI 5.6 with fresh install (multi-php) when you edit admin user? I’ve changed that to 7.3.
Probably just a bug. php -v
would probably say php 7.3.9
You are right, php -v says 7.3
so that thing 5.6 cli in interface is a bug.
Yes, Could you make a bug report?
Url has changed now to https://docs.hestiacp.com/admin_docs/dns.html#how-to-setup-a-dns-cluster
DNS Management / DNS server — Hestia Control Panel documentation (hestiacp.com)
(In case you get here from a google search and want to go to the doc directly )
