Hestia for Node.js?
Hi all,
I am using Plesk right now, but I want to switch to a open source solution. HestiaCP sounds very good.
I read a lot, it is a good fit for PHP. But I mostly work with node.js, react.js, next.js, redis and mongodb (a lot JavaScript and TypeScript stack).
Would this also work, as none of them really is PHP related?
Thanks and best regards!
Nodejs has been already discussed here: Node.js support - #2 by salnz
You can nearly run all the applications you wrote there with a custom template (see our docs).
