Hestia login for the admin user stopped working. After entering password, it prompts again for Username, as if the password was wrong. However, the “Invalid username or password” or any other error message is not displayed. It worked fine before. I did not upgrade or change anything in Hestia. I tried changing the password with /v-change-user-password
. /var/log/hestia/auth.log
is empty. Does anyone know what could be wrong?
Did you check Nginx error log /var/log/hestia/nginx-error.log
Do you have enough disk space?
df -h /usr/local/hestia
It appears that this partition has ran out of disk space. Thank you for your help.
