Hestia logs me out automatically
Trying to add a new “web domain” and I get automatically logged out of Hestia.
I have no idea why this is happening.
This is on a fresh Ubuntu 20.04 Server. Linode 4gb
Can anyone try and reproduce this.
Not able to reproduce here, adding domains works perfectly. Would need a debug and more informations if you would want to solve the problem.
No issue over here…
Even with your login data. Will remove them
Could this be from my cookies?
Could be. Just clear them and see what happens…
found any solution?? facing the same issue after clean install on 08/02/2023
Changing ips randomly?
Is there a fix for this?
Easiest method use a VPN with a fixed ip.
I have tried a different browsers or different computer to isolate the issue?
