Hestia-nginx updates ⚠
Hestia Control Panel: v1.6.8
Operating System: Debian 11.4 (x86_64)
Hello, please tell me what to do?
On my update page (https://ip:8083/list/updates/), section “Package” hestia-nginx, has the status :warning: (yellow triangle with an exclamation mark), If I want to send a message to someone, it is not sent and I get messages in the mail - From: Mail Delivery System [email protected], message - This message was created automatically by mail delivery software.
A message that you sent has not yet been delivered to one or more of its
recipients after more than 72 hours on the queue on cp.mydomain.com.other.
The message identifier is:
The date of the message is:
The subject of the message is:
The address to which the message has not yet been delivered is:
No action is required on your part. Delivery attempts will continue for
some time, and this warning may be repeated at intervals if the message
remains undelivered. Eventually the mail delivery software will give up,
and when that happens, the message will be returned to you.
Reporting-MTA: dns; localhost
Action: delayed
Final-Recipient: rfc822; [email protected]
Status: 4.0.0
Return-path: [email protected]
Received: from localhost ([127.0.0.1] helo=webmail.cp.mydomain.com)
by cp.mydomain.com with esmtpa (Exim 4.94.2)
(envelope-from [email protected])
id 1oVY2Y-001i6e-VY
for [email protected]; Tue, 06 Sep 2022 12:50:54 +0000
MIME-Version: 1.0
Date: Tue, 06 Sep 2022 15:50:54 +0300
To: [email protected]
Subject: =?UTF-8?Q?=D0=A0=D0=B0=D0=B1=D0=BE=D1=82=D0=B0=D0=B5=D1=82=D0=B5?=
=?UTF-8?Q?=D0=BB=D0=B8=D1=81_1=D1=81=3F?=
Message-ID: [email protected]
X-Sender: [email protected]
Content-Type: text/plain; charset=UTF-8;
format=flowed
Content-Transfer-Encoding: 8bit
I did restart, but it doesn’t help. Thank you if you can help. I’m a beginner. So I don’t know all the ins and outs. If you need any more information, please write it.
Run apt-get update && apt-get upgrade in command line that will solve the hestia-nginx issues
Thank you! It works!
But my email messages are not sent, what to do in this case?
I use digitalocean. Port 25 open
Check /var/log/exim4/mainlog
Block 25 outgoing is blocked
Thanks! My port 25 block? Sorry… I just don’t understand what google has to do with it when I use digitalocean.
This is topic for me?
You are sending with gmail-smtp-in.l.google.com and is failing to connect. So the port is blocked
