Hestia Restic Incremental Backups configuration
Hi team, as per the old method, the cron job for the v-backup-users used to be executed to backup all the users with the same package where the backup configuration was enabled.
Now with the introduction of restic backups, I tried configuring the backups by enabling the incremental backups in the package and the incremental backup configuration on the server configuration. Yet I find the backups are not taking place. Do we need to set up the v-backup-users-restic in place of v-backup-users in the crontab for the hestiaweb user to enable the incremental backups? Or am I missing any configuration?
Is there anyone here who can help with this query?
Yes you need to add the v-backup-users-restic to the cronjob list
Thank you so much for your response. I will make the changes and let you know if they work correctly.
