I have setup SMTP relay with Sendinblue
You need to check the exim mainlog to see whats going wrong.
“Web” UI mails are send over sendmail…
Run hestiacp/configure-server-smtp.sh at main · hestiacp/hestiacp · GitHub
Once and it should be setup
mail receive function is working fine but when I send an email its not appear in receiver’s inbox
Does it happen with any domain?
- same machine (other domain hosted on that machine)
- domains hosted on other machines
- big providers such as Gmail
i have used Gmail address for testing
Then try the rest. Maybe it is only a delivery problem with Gmail.
Check your DNS record:
- SPF
- DMARC
It could also be that google has banned your IP and it is not telling you.
Are you receiving bounce emails? In that case, show us a copy.
I have checked with a lot of other email providers still same issue
Check /var/log/exim4/mainlog
This is exactly where I start from. Usually I go to the command line and run: watch exigrep [email address here] /var/log/exim4/mainlog
to see in almost real time what is happening. Apparently you need to replace the [email address here] (and remove brackets as well) with the sender or receiver address.
In another window, I send the test email message. Then I go back to the command line and check the latest entry at the bottom. When I see something like the following, I can be sure that the email was delivered to the recipient server: 2022-03-16 10:17:46 1nUOqo-0018O9-6W Completed
It worked I got the error message that my SMTP account was not activated
2022-03-16 00:49:34 1nU7u4-002kYp-Sh == R=send_via_smtp_relay T=smtp_relay_smtp defer (-46) H=smtp-relay.sendinblue.com [185.107.232.248]: SMTP error from remote mail server after end of data: 450 Your SMTP account is not yet activated. Please contact us at [email protected] to request activation.
