<?php
// This module sponsered by our good friends from wexcloud.com
function vesta_ConfigOptions() {
$configarray = array(
"Package Name" => array( "Type" => "text", "Default" => "default"),
"SSH Access" => array( "Type" => "yesno", "Description" => "Tick to grant access", ),
"IP Address (optional)" => array( "Type" => "text" ),
return $configarray;
function vesta_CreateAccount($params) {
// Execute only if there is assigned server
if ($params["server"] == 1) {
// Prepare variables
$postvars = array(
'user' => $params["serverusername"],
'password' => $params["serverpassword"],
'hash' => $params["serveraccesshash"],
'cmd' => 'v-add-user',
'arg1' => $params["username"],
'arg2' => $params["password"],
'arg3' => $params["clientsdetails"]["email"],
'arg4' => $params["configoption1"],
'arg5' => $params["clientsdetails"]["firstname"],
'arg6' => $params["clientsdetails"]["lastname"],
$postdata = http_build_query($postvars);
// Create user account
$curl = curl_init();
curl_setopt($curl, CURLOPT_URL, 'https://' . $params["serverhostname"] . ':8083/api/');
curl_setopt($curl, CURLOPT_RETURNTRANSFER,true);
curl_setopt($curl, CURLOPT_SSL_VERIFYPEER, false);
curl_setopt($curl, CURLOPT_SSL_VERIFYHOST, false);
curl_setopt($curl, CURLOPT_POST, true);
curl_setopt($curl, CURLOPT_POSTFIELDS, $postdata);
$answer = curl_exec($curl);
logModuleCall('hestia','CreateAccount_UserAccount','https://'.$params["serverhostname"].':8083/api/'.$postdata,$answer);
// Enable ssh access
if(($answer == 'OK') && ($params["configoption2"] == 'on')) {
$postvars = array(
'cmd' => 'v-change-user-shell',
'arg2' => 'bash'
logModuleCall('hestia','CreateAccount_EnableSSH','https://'.$params["serverhostname"].':8083/api/'.$postdata,$answer);
// Add domain
if(($answer == 'OK') && (!empty($params["domain"]))) {
$postvars = array(
'cmd' => 'v-add-domain',
'arg2' => $params["domain"],
'arg3' => $params["configoption3"],
logModuleCall('hestia','CreateAccount_AddDomain','https://'.$params["serverhostname"].':8083/api/'.$postdata,$answer);
if($answer == 'OK') {
$result = "success";
} else {
$result = $answer;
return $result;
function vesta_TerminateAccount($params) {
$postvars = array(
'cmd' => 'v-delete-user',
// Delete user account
logModuleCall('hestia','TerminateAccount','https://'.$params["serverhostname"].':8083/api/'.$postdata,$answer);
} else {
$result = $answer;
return $result;
function vesta_SuspendAccount($params) {
$postvars = array(
'cmd' => 'v-suspend-user',
// Susupend user account
logModuleCall('hestia','SuspendAccount','https://'.$params["serverhostname"].':8083/api/'.$postdata,$answer);
} else {
$result = $answer;
return $result;
function vesta_UnsuspendAccount($params) {
$postvars = array(
'cmd' => 'v-unsuspend-user',
// Unsusupend user account
logModuleCall('hestia','UnsuspendAccount','https://'.$params["serverhostname"].':8083/api/'.$postdata,$answer);
} else {
$result = $answer;
return $result;
function vesta_ChangePassword($params) {
$postvars = array(
'cmd' => 'v-change-user-password',
// Change user package
logModuleCall('hestia','ChangePassword','https://'.$params["serverhostname"].':8083/api/'.$postdata,$answer);
} else {
$result = $answer;
return $result;
function vesta_ChangePackage($params) {
$postvars = array(
'user' => $params["hstadmin"],
'password' => $params["hstadminpw"],
'returncode' => 'no',
'cmd' => 'v-check-user-password',
curl_setopt($curl, CURLOPT_HEADER,false);
curl_setopt($curl, CURLOPT_URL, 'https://' . $params["hostname"] . ':8083/api/');
logModuleCall('hestia','ChangePackage','https://'.$params["hostname"].':8083/api/'.$postdata,$answer);
} else {
$result = $answer;
return $result;
function vesta_ClientArea($params) {
$code = '<form action="https://'.$params["serverhostname"].':8083/login/" method="post" target="_blank">
<input type="hidden" name="user" value="'.$params["username"].'" />
<input type="hidden" name="password" value="'.$params["password"].'" />
<input type="submit" value="Hestia panel Girişi" />
<input type="button" value="web mail girişi" onClick="window.open(\'https://webmail.'.$params["domain"].'/\')" />
<input type="button" value="Phpmyadmin giriş" onClick="window.open(\'https://'.$params["domain"].'/phpmyadmin\')" />
</form>';
return $code;
function vesta_AdminLink($params) {
$code = '<form action="https://'.$params["serverhostname"].':8083/login/" method="post" target=\"_blank\">
</form>';
return $code;
function vesta_LoginLink($params) {
echo "<a href=\"https://".$params["serverhostname"].":8083/login/\" target=\"_blank\" style=\"color:#cc0000\">control panel</a>";
function vesta_UsageUpdate($params) {
$postvars = array(
'cmd' => 'v-list-users',
'arg1' => 'json'
// Get user stats
// Decode json data
$results = json_decode($answer, true);
// Loop through results and update DB
foreach ($results AS $user=>$values) {
update_query("tblhosting",array(
"diskusage"=>$values['U_DISK'],
"disklimit"=>$values['DISK_QUOTA'],
"bwusage"=>$values['U_BANDWIDTH'],
"bwlimit"=>$values['BANDWIDTH'],
"lastupdate"=>"now()",
),array("server"=>$params['serverid'], "username"=>$user));
Combine them in one or wait until 1.4.0 has been released or patch v-add-user manually see main branch at GitHub
Hi. Do you have a document on how to set this up?
I added a video to the download link
