eris
May 4, 2021, 12:15pm
#1
1.4 Beta version has just been build and available for download via:
https://apt.hestiacp.com/beta/hestia_1.4.0~beta_amd64.deb
Please download the package via:
wget https://apt.hestiacp.com/beta/hestia_1.4.0~beta_amd64.deb
dpkg -i hestia_1.4.0~beta_amd64.deb
If no new issues will rise we will aim the release of 1.4 in about 2 weeks.
Change log:
# Changelog
All notable changes to this project will be documented in this file.
## [DEVELOPMENT]
- **NOTE:** Ubuntu 16.04 (Xenial) is no longer supported as it has reached EOL (end-of-life) status.
- **NOTE:** Apache in "standalone" mode is no longer actively supported and has been removed from installer options. Nginx (Proxy) + Apache2 will remain supported.
- **NOTE:** Custom "quick installer apps" will not work anymore due to changes in how we handle quick installer apps. Minimal changes to the Quick installer apps are required! Please check https://github.com/jaapmarcus/hestia-quick-install for how to migrate!
### Features
- Introduced single sign-on support for phpMyAdmin.
- Introduced support for NGINX FastCGI cache.
- Introduced support for SMTP Relay / smarthosts (server-wide or per-domain).
- Introduced the ability to choose which webmail client to use per-domain (Roundcube or Rainloop).
- Added B2 Backup Support for Remote Backup Location - thanks **@rez0n**!
- Added template support for osTicket - thanks **@madito**!
- Packages for phpMyAdmin, Roundcube, and Rainloop will be pulled directly from their upstream source instead of APT for new installations.
- Added DNS records view to mail domains which provides DKIM, SPF, and other entries to use with an external provider.
- Added an upgrade script to provide in-place upgrades to php7.4 (or any other version).
- Added Drupal and Nextcloud quick installer support (Removed placeholder Joomla)
This file has been truncated. show original
Also new strings have been added to Hestia CP < GlotPress . If you are able to help us to translate Hestia in your native language. We appreciate it and we could use all the help!
If you have created your own quick install apps please check GitHub - hestiacp/hestia-quick-install as 1.4 will break current quick install apps!
