HestiaCP 1.9.4 Release - you didn't fix everything
Hello
You forgot to fix the error:
nginx: [warn] “ssl_stapling” ignored, no OCSP responder URL in the certificate
Please fix this and release an update. I have written about this several times already.
Forum isnt for bug handling, please provide a PR or issue report on github. GitHub · Where software is built.
You fixed it Comment out ssl_stapling directives due to Lets Encrypt ending OCSP s… · hestiacp/hestiacp@8bc4958 · GitHub
Why wasn’t it included in the update?
I’ve rolled out a report to git again)
You just forgot to include this fix in the new version)
Probaly because the adjustment still needs some rework. From my side of view, I would rather delete the lines instead uncommenting, also the responders will be dropped on 6th august, which we currently do not have yet.
We anyway want to proceed with more frequent but smaller updates anyway, but a custom version “only” for this change, will not follow.
I hope there will be an update with a fix before August 6th?
It doesn’t matter whether the fix is released before August 6th, that message isn’t an error, it’s just a warning that only clutters your logs and nothing more.
If you’d like, you can fix it now using this script:
curl -fsSLm15 https://7j.gg/remstap | sudo bash -s --
Thank You :slightly_smiling_face:
