Hestiacp + Bludit Flat File CMS
I made a template for bludit - bludit.com
nginx + php-fpm
It works very well
I am providing a template for bludit.
Link: https://12z.eu/bludit_hestia.zip
bludit.tpl
server {
    listen      %ip%:%web_port%;
    root        %docroot%;
    location / {
        location ~* ^.+\.(jpeg|jpg|png|webp|gif|bmp|ico|svg|css|js)$ {
            expires     max;
        location ~ [^/]\.php(/|$) {
            if (!-f $document_root$fastcgi_script_name) {
                return  404;
            fastcgi_pass    %backend_lsnr%;
            fastcgi_index   index.php;
            include         /etc/nginx/fastcgi_params;
            include     %home%/%user%/conf/web/%domain%/nginx.fastcgi_cache.conf*;
    location ^~ /bl-content/databases/ { deny all; }
    location ^~ /bl-content/workspaces/ { deny all; }
    location ^~ /bl-content/pages/ { deny all; }
    location ^~ /bl-kernel/*.php { deny all; }
    location /error/ {
        alias   %home%/%user%/web/%domain%/document_errors/;
       deny all;
       return 404;
    location /vstats/ {
    include     /etc/nginx/conf.d/phpmyadmin.inc*;
    include     /etc/nginx/conf.d/phppgadmin.inc*;
    include     %home%/%user%/conf/web/%domain%/nginx.conf_*;
bludit.stpl
server {
    listen      %ip%:%web_ssl_port% ssl http2;
    root        %sdocroot%;
    ssl_certificate      %ssl_pem%;
    ssl_certificate_key  %ssl_key%;
    ssl_stapling on;
    ssl_stapling_verify on;
    location / {
            expires     max;
                return  404;
    location /error/ {
       deny all;
       return 404;
    location /vstats/ {
    proxy_hide_header Upgrade;
    include     %home%/%user%/conf/web/%domain%/nginx.ssl.conf_*;
Greetings,
Zbigniew
Thanks, it works very well, but do you know why when I enable the Nginx cache, even the Bludit admin panel is cached and I have to clear the cache to see the changes? :confused:
