jobet
#1
I wanted to contribute with the Hestia docs, so I forked your hestia repo into my GitHub account.
I made a few changes in the backups section, then saving changes I created a new branch (GitHub - jobetinfosec/hestiacp-docs at jobetinfosec-patch-1) and did a Pull request to merge changes into my repo’s Master branch…
As I’m not very familiar with GitHub, I was wondering if it’s the right way to do this…
eris
#2
Almost…
When you open a pull request make sure you select: hestiacp/hestia-docs and then branch master
jobet
#3
Ok, so I have to make the “Pull request” directly into your repo… not mine…
jobet
#4
ScIT
#5
No, all is well - we will review and merge your change soon. Thank you!
jobet
#6
Ohh great! my first contribution!!
system
closed
#8
