In the evening there was no error, I woke up and went to the panel HestiaCP and I see:
Internal Server Error
Oops! Something went wrong.
The server encountered an internal error or misconfiguration and was unable to complete your request.
Error Code: 500
nginx-error.log:
2022/10/07 16:38:09 [error] 3138#0: *3 FastCGI sent in stderr: "PHP message: PHP Warning: session_start(): open(/usr/local/hestia/data/sessions/sess_26a973052933lmpokvo1fbt1fj, O_RDWR) failed: Permission denied (13) in /usr/local/hestia/web/index.php on line 2PHP message: PHP Warning: session_start(): Failed to read session data: files (path: /usr/local/hestia/data/sessions) in /usr/local/hestia/web/index.php on line 2" while reading response header from upstream, client: {IPMY}, server: _, request: "GET / HTTP/1.1", upstream: "fastcgi://unix:/var/run/hestia-php.sock:", host: "cl.mydomain:8083"
2022/10/07 16:38:09 [error] 3138#0: *3 FastCGI sent in stderr: "PHP message: PHP Warning: session_start(): open(/usr/local/hestia/data/sessions/sess_26a973052933lmpokvo1fbt1fj, O_RDWR) failed: Permission denied (13) in /usr/local/hestia/web/inc/main.php on line 2PHP message: PHP Warning: session_start(): Failed to read session data: files (path: /usr/local/hestia/data/sessions) in /usr/local/hestia/web/inc/main.php on line 2PHP message: PHP Warning: Trying to access array offset on value of type null in /usr/local/hestia/web/inc/main.php on line 498PHP message: PHP Warning: foreach() argument must be of type array|object, null given in /usr/local/hestia/web/inc/main.php on line 499PHP message: PHP Warning: Undefined array key "RELEASE_BRANCH" in /usr/local/hestia/web/inc/main.php on line 102PHP message: PHP Warning: Trying to access array offset on value of type null in /usr/local/hestia/web/inc/main.php on line 498PHP message: PHP Warning: foreach() argument must be of type array|object, null given in /usr/local/hestia/web/inc/main.php on line 499PHP message: PHP Warning: Trying to access array offset on value of type null in /usr/local/hestia/web/login/index.php on line 316PHP message: PHP Warning: Trying to access array offset on value of type null in /usr/local/hestia/web/login/index.php on line 316PHP message: PHP Fatal error: Uncaught TypeError: in_array(): Argument #2 ($haystack) must be of type array, null given in /usr/local/hestia/web/login/index.php:321
Stack trace:
#0 /usr/local/hestia/web/login/index.php(321): in_array()
#1 {main}
thrown in /usr/local/hestia/web/login/index.php on line 321" while reading response header from upstream, client: {IPMY}, server: _, request: "GET /login/ HTTP/1.1", upstream: "fastcgi://unix:/var/run/hestia-php.sock:", host: "cl.mydomain:8083"
