Hi, I have installed a hestiacp in a fresh server and i migrated my files and db from my old server(using vesta) after the migration process i can access the panel but not filemanger. When i access the filemanager it shows “Unknown Error”
I have checked the log “tail -f /var/log/hestia/nginx-error.log” it returns
2025/02/19 05:42:52 [error] 557#0: *3 FastCGI sent in stderr: “PHP message: PHP Warning: ini_set(): Session ini settings cannot be changed when a session is active in /usr/local/hestia/web/fm/vendor/symfony/http-foundation/Session/Storage/Handler/NativeFileSessionHandler.php on line 53” while reading response header from upstream, client: 117.247.105.10, server: _, request: “GET /fm/?r=/getuser HTTP/2.0”, upstream: “fastcgi://unix:/run/hestia-php.sock:”, host: “IP:8083”, referrer: “https://IP:8083/fm/”
2025/02/19 05:42:53 [error] 557#0: *3 FastCGI sent in stderr: "PHP message: PHP Warning: ini_set(): Session ini settings cannot be changed when a session is active in /usr/local/hestia/web/fm/vendor/symfony/http-foundation/Session/Storage/Handler/NativeFileSessionHandler.php on line 53; PHP message: PHP Fatal error: Uncaught League\Flysystem\Sftp\ConnectionErrorException: Could not login with username: admin, host: 127.0.0.1 in /usr/local/hestia/web/fm/vendor/league/flysystem-sftp/src/SftpAdapter.php:244
Stack trace:
#0 /usr/local/hestia/web/fm/vendor/league/flysystem-sftp/src/SftpAdapter.php(207): League\Flysystem\Sftp\SftpAdapter->login()
#1 /usr/local/hestia/web/fm/vendor/league/flysystem/src/Adapter/AbstractFtpAdapter.php(650): League\Flysystem\Sftp\SftpAdapter->connect()
#2 /usr/local/hestia/web/fm/vendor/league/flysystem-sftp/src/SftpAdapter.php(360): League\Flysystem\Adapter\AbstractFtpAdapter->getConnection()
#3 /usr/local/hestia/web/fm/vendor/league/flysystem/src/Adapter/AbstractFtpAdapter.php(338): League\Flysystem\Sftp\SftpAdapter->listDirectoryContents()
#4 /usr/local/hestia/web/fm/vendor/league/flysystem/src/Filesystem.php(272): League\Flysystem\Adapter\AbstractFtpAdapter->listContents()
#5 /usr/local/hestia/web/fm/backend/Services/Storage/Filesystem.php(266): League\Flysys" while reading response header from upstream, client: 117.247.105.10, server: _, request: “POST /fm/?r=/getdir HTTP/2.0”, upstream: “fastcgi://unix:/run/hestia-php.sock:”, host: “IP:8083”, referrer: “https://IP:8083/fm/”
What may be the problem and any workaround please?
