precell
September 25, 2022, 10:47am
1
I do not speak English. So I have to deal with Google translator
Hello, honorable HestiaCP community
How to connect the reverse proxy nginx under jellyfin? The Jellifin documentation method does not work. I have a supodomena connected to Hestiacp. HestiaCP generates its own NGINX configuration files, probably the problem is here.
Documentation Jellyfin:
https://jellyfin.org/docs/general/networking/nginx.html
Regards
Raphael
September 25, 2022, 12:07pm
2
Create a custom template, it should basicly w9rk but i kever tried ojt jellyfin: Web domains and SSL Certicates โ Hestia Control Panel documentation
precell
September 25, 2022, 2:13pm
3
I created a new jellyfin.tpl template. I chose it in the HestiaCP panel for subdomain. And I have a message: Error: jellyfin proxy template doesnโt exist
Raphael
September 25, 2022, 2:25pm
4
you need to create both, tpl and stpl
precell
September 25, 2022, 7:08pm
5
Not work. Under the subdomain, it is displayed:
Weโre working on it!
This site is currently under construction.
Please check back soon.
precell
September 27, 2022, 8:40am
6
I tried this for http:
Im running HestiaCP 1.2.1 on ubuntu 20.04. Im using my current server as a webserver and installed couple of docker apps ie. plex,sonar,radar). Im using cloudflare as my DNS (mainly because of the auto ssl feature)
My objective is to reverse proxy + ssl for all my docker apps. My settings are as below for eg.plex
docker app: Plex
port: 32400
domain: plex.mydomain.com
Iโll add nginx config for the domain to
/etc/nginx/conf.d/domains/plex.mydomain.com.conf
with the following setting:
server โฆ
It works for me.
server {
listen %ip%:%proxy_port%;
server_name %domain%;
location / {
proxy_pass http://%ip%:8096;
An example from Jellyfin documentation does not work. Why?
server {
listen %proxy_port%;
listen [::]:%proxy_port%;
access_log /var/log/nginx/jellyfin.access;
error_log /var/log/nginx/jellyfin.error;
set $jellyfin %ip%;
location / {
proxy_set_header Host $host;
proxy_set_header X-Forwarded-Protocol $scheme;
proxy_set_header X-Forwarded-Host $http_host;
# Disable buffering when the nginx proxy gets very resource heavy upon streaming
proxy_buffering off;
# location block for /web - This is purely for aesthetics so /web/#!/ works instead of having to go to /web/index.html/#!/
location ~ ^/web/$ {
# Proxy main Jellyfin traffic
proxy_pass http://$jellyfin:8096/web/index.html/;
location /socket {
# Proxy Jellyfin Websockets traffic
proxy_pass http://$%ip%:8096;
proxy_http_version 1.1;
proxy_set_header Upgrade $http_upgrade;
proxy_set_header Connection "upgrade";
# Security / XSS Mitigation Headers
add_header X-Frame-Options "SAMEORIGIN";
add_header X-XSS-Protection "1; mode=block";
add_header X-Content-Type-Options "nosniff";
