Hestiacp web page isn't working issue
Hi, After installing hestiacp in a fresh server (ubuntu 22.04) I often get " This page isn’t working
************** redirected you too many times.
ERR_TOO_MANY_REDIRECTS" when try to access the login page.
Why it’s coming like that and any solution please?
Are you using Cloudflare?
Yes, I am using cloudflare
Check SSL settings with in Cloudflare
When i access ip:8083 that page isn’t working error coming
The domain is working perfectly. only my hestiacp login page throws this error and after reloading the page it’s working.
You shouldn’t be accessing via IP. You will get a certificate waring. You also can’t use Cloudflare with port 8083. They don’t proxy that port without a Spectrum plan. You would need to move the HestiaCP interface to listen on 2083 or another supported port.
Oh okay thank you for the solution.
